Old 12-02-2024, 12:19 AM
67drake's Avatar
67drake 67drake is offline
Default Oil capacity on ‘55 287-6 quarts? Way low on dipstick
I bought my ‘55 a few months back. I decided to do an oil and filter change on it this weekend as I’m done driving it for the season now.
So I drain the oil and drop the filter housing and drop in a new canister filter. Manual says 6 quarts with a filter change. I’m showing at least a quart and a half low after firing it up and letting it sit awhile!?
So is the manual wrong or did someone replace the dipstick with the wrong one? As far as I know the engine is the original 287. It may be hard to see, but the oil is just at the very tip of the dipstick.
Any ideas?
‘55 Catalina
Old 12-02-2024, 04:23 PM
jamesq's Avatar
jamesq jamesq is offline
I vote wrong dip stick.
I checked my 1955 Chiltons and it agrees with your six qt capacity.
James Q
James Quayhagen
The Following User Says Thank You to jamesq For This Useful Post:
Old 12-04-2024, 09:43 PM
67drake's Avatar
OK. So does anyone have a original’55 dipstick they could measure from tip to the seating stopper?
I mean if it was a quart quart off I wouldn’t worry about it, but almost 2 quarts?
Plus, the way it is now, if it gets a little low, it’s not going to be readable on the stick, so I will have no idea how much to add to top it off.
‘55 Catalina
Old 12-05-2024, 03:41 PM
jamesq's Avatar
There's on on ebay, but it's pricey!
https://www.ebay.com/itm/15597697217...3ABFBM_oauhfNk
James Q
James Quayhagen
Old 12-05-2024, 06:11 PM
67drake's Avatar
James Q
That’s definitely different than my dipstick. For starters mine has a bend in it from the add to full mark like I pictured.
‘55 Catalina
Old 12-05-2024, 06:14 PM
Place an ad here for a dipstick.
Until you find one just keep putting 6 quarts in it and just check the oil level on that stubby stick more often.
No way does that little 287 need more than 6 quarts total with the filter.
Old 12-05-2024, 06:24 PM
67drake's Avatar
I agree. I just texted the previous owner to see if he knew of its origin. He was probably overfilling it this whole time. You would think somewhere along the line someone would have questioned why it took 7-8 quarts after changing the oil. Based on the other thread I started showing the doubled up filter gasket, I guess I’m not really surprised.
‘55 Catalina
Old 12-05-2024, 06:40 PM
Bill Hanlon's Avatar
55-58 Pontiac and 55-58 GMC (Pontiac) V8 engines used the same part number 518006 oil pan. The GMC Maintenance Manual calls for 5 quarts plus one for the filter.
Old 12-05-2024, 06:48 PM
694.1 694.1 is offline
the 57s used 2 different dipsticks, so there is that.
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 12-05-2024, 07:53 PM
Yes, A/C cars had one (and a longer tube) and non-A/C had a shorter one.
Old 12-05-2024, 08:03 PM
67drake's Avatar
Great info. My car is not an A/C car, so that’s a possibility if someone stuck the wrong stick or tube on there.
I still wish I could find someone with an identical car so that they could measure from the tip of the dipstick to the cap that seats against the tube.
‘55 Catalina
Old 12-06-2024, 12:09 AM
If you find one, have the length of the tube from the block up to the open end as well.
