Does anyone have the felpro part number for the Pontiac thermostat gasket? The last time I needed a gasket I had trouble finding the number for just a gasket. Had to pull one out of a kit.
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55 '72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80 |
Pm me your address I’ll send you one.
My OG was alum, I do have an extra for sale.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Southern Hamtramck Institute of Technology , Alumni Put some 8” flakes and BFG’s on dude!, like everyone does🙄 Burds Literature, nOS factory Brochures, Glovebox literature, & black & blue freedom toppers. 1978 YEE 1995 Q45 #whoremembers |
http://nitemareperformance.com/waterneck-pro.html |
Hey thank you for the offer! I’ve actually made a couple extra with some gasket material so I’m good for now. I was hoping to get the felpro part number because they use to be available specifically for Pontiacs with the correct bolt spacing. Seems like the only ones I could find were a universal style with slotted holes.
I’ve used both the aluminum and cast iron water necks and haven’t had an issue with leaks ever since I started sanding the gasket surface to ensure flat, using the Permatex thermostat and waterpump RTV (no gasket), and not over tightening.
https://www.amazon.com/Permatex-2207...35178778&psc=1
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
| The Following User Says Thank You to grivera For This Useful Post: | ||
If anyone was curious, like I was, it appears no aftermarket T-stat housing gaskets are Pontiac specific, they’re universal slotted hole jobs.
If one wants a dedicated gasket, one has to patronize Butler, KRE, BOP, etc. as they all appear to have them. Probably all made by one place, TIP I would assume?
costs too much |
Eventually I'd like to add a laser cutter to my shop, sure would be nice to be able to cut gaskets out of any material you want, sized perfectly to any application. Laser cutters capable of cutting gasket material are well within the $1000 price range.
| The Following User Says Thank You to dataway For This Useful Post: | ||
I use a chevy chrome housing with the o ring. Only modification was to use a rat tail file and elongate the mtg. Hole pattern out a little bit for pontiac bolt pattern. The amount is so small that the bolt heads still cover it. Also I use 240 sandpaper on flat steel sanding block to make sure it's good and flat
These chrome T-stat housings are usually a universal fit for most GM vehicles that use this angle housing, on all the Mr Gasket ones I used they didnt say pontiac on the package but never had to elongate the bolt holes, they mount to a pontiac intake without any issues in my experience.
But, looking at summit, they have a Trans-Dapt brand that says its for pontiac V8, most others say for big/small block chevy... https://www.summitracing.com/parts/trd-9230 |
CSR used to make an adjustable aluminum Pontiac one.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
I have the solution, I modeled and printed up a universal thermostat housing.
Franken.... What?!?!?! Lol
