#101
1967 Firechicken, 499", Edl heads, 262/[email protected]" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. [email protected] mph with a 1.45 60'. Still WAY under the rollbar rule. |
| The Following User Says Thank You to AG For This Useful Post: | ||
#102
From the old HO racing catalog.
#103
Craig and Kern, they knew what they were doing.
#104
Curiously that fact was never mentioned in their "High Performance Engine Design" book or their Pontiac Performance magazine articles.
#105
Heads are done, spring bosses have been machined and all Comp Cam springs are installed to exactly 1.8" with only one valve needing a 1/16" shim. New Viton seals, retainers, 1.65 roller tip rockers, new poly-locks and the stock 9.2" pushrods fit perfectly. All adjusted to 1/2 turn past contact. Sheesh. I hope I never have top adjust this beast again. Now to put everything back.
Quick question: the engine was painted at the factory with the valley cover and oil pan in place, right? So those fasteners would have been painted also. |
#106
For some unknown reason, my I-phone photos for January did not upload into the computer, but they are back for February???
Here is the fully machined and reassembled RTAIV motor - valve guide bosses milled, springs all set to 1.8" and checked at 112 lbs seat pressure, new valve seals, lifters, cam, pushrods. Geometry checked and double-checked and perfect. Painted with Eastwood's ceramic engine paint, supposedly good to 500 degrees. I willl take and hopefully upload some pics today. |
#107
112 psi on the seat is not much boy, especially for the intake valve!
These motors left the factory with 124 on the seat and over 340 open @ .520” .
#108
1969 RA III uses 124 lb on the seat, NOT RAIV. 112 lb on the seat will be just fine.
#109
When the springs break in all the way and drop 10 lbs out will see how fine he is if the valves float or bounce on and off the seat.
He will stand a good chance of bending stuff again. The RA4 valves being taller then the D port valves of the RAIII weight more, so more pressure is needed. The 30 degree seat intake seat and valve needs more spring pressure then a 45 seat does to ward off seat bounce. A 30 degree seat clamps to seal more then a 45 seat that both clamps and wedges to make a seal.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 02-09-2025 at 08:04 AM. |
#110
The RAIV springs were good for at least 6100 rpm`s w/o "bouncing", how bad is that?
And, RAIV heads uses 30° intake seats, like all large inte valve heads, (except 455 S.D.). NOT 45° intake seats. Last edited by Kenth; 02-09-2025 at 09:07 AM. |
#111
Don't forget, this car will probably never see 5000 RPM. It's a convertible, too heavy to race and in all likelihood a show car that will end up in some collection eventually. RELIABILITY is what I'm looking for here at the risk of losing a bit of high RPM potential.
#112
Put some RAIV valves and D'port valves on a actual scale see what the real results are, the RAIV'ex valves might be a tick heavier but RAIV intakes are are substantially lighter than stock D's.. and intakes will float first
A 1/8 longer stem does not compair to what goes away in the tulip I have done this comparison Aftermarket valves are typically lighter than stockers as well
........... The More You Follow The Herd The Less You Can Be In The Lead .......... Last edited by Formulas; 02-09-2025 at 11:53 AM. |
#113
Trans, clutch, shifter, starter, linkage, exhaust, driveshaft, etc all re-installed. What a pain. Now to finish the top parts, pre-lube and break her in.
| The Following User Says Thank You to Jimbobeast For This Useful Post: | ||
#114
The seat pressure was not the problem in wiping your previous cam. If you used a high rate spring on a short IH, your spring pressure over the nose increased by a large factor. Unless your cam wiped the base circle?
Over the nose pressure on a HFT should be kept in check. Well, the ones you want to last anyhow... |
#115
The boss is now machined and the inner springs are flat on the seat along with the outers. All is in harmony. |
#116
Also, I would not trust anyone, Pontiac friendly or not, who did not verify a spring fits before installing. Not by a country mile. The issue should have been caught when checking the spring pressures before sending the heads out the door too. Two strikes right there. The third would be them willing to fix it for free. I'd run the other way with the heads you have. Scary really. |
#117
My 995 springs were broken in prior (used) but to answer your question, I would say the pressures would drop after break in as expected. Just like the factory spring would and specs Kenth posted. The factory probably understood the initial pressure loss and springs are spec't accordingly.
I have a question for you too Paul. After initial break-in and loss of pressure, is it assumed that valve springs are stable and will last forever? Or will they wear based on cycles that decline over time with use? My thinking here is the decline after breakin might be slow but still there and wanted to get your thoghts. |
#119
I do love the looks of an Orbit Orange/Black Top '70 Judge convertible, even in the garage. Always have. |
#120
| The Following User Says Thank You to PAUL K For This Useful Post: | ||
