Old 01-13-2025, 10:53 PM
moneypit's Avatar
moneypit moneypit is offline
I will take the last one!
Sent you a pm with info.
Thanks!!
Colt.
37 Pontiac Sedan 455 700r4
94 Firehawk Supercharged 5.7 LT1 6spd.
71 GTO base 400 A/T
97 F250 7.3 turbo diesel
The Following User Says Thank You to moneypit For This Useful Post:
  #562
Old 01-13-2025, 11:45 PM
I imagine a lot of us wish we would have or could have grabbed one of them.
Is anyone building a 65 GTO prototype test car with 2x4 induction ?
  #563
Old 01-13-2025, 11:53 PM
tom s tom s is offline
I’m sure if John got enough orders he would order more castings.I think he had to get 10 at a time.Tom
  #564
Old 01-14-2025, 11:10 AM
ANDYA ANDYA is offline
Baron, that’s what I’m looking to do with mine. I have a 65 421 block and heads that still needs to be built. Hopefully I will be able to fit air cleaners under the hood of my GTO with the bathtub. I think if Pontiac was going to do a 2x4 prototype test car the manifold would have been more of a low rise for hood clearance and air clearance. My idea is more of a home built day 2 street racer car. In other words, what if Pontiac offered the bathtub manifold over the counter for 65 and up heads. Anyone could buy it and put it on any car they wanted.
  #565
Old 05-11-2025, 05:17 AM
62GPSD 62GPSD is offline
I dont want to go that road,IF I loose my mind and decide to do this it will be 65 up water pattern.If someone wants to run it on early heads they would need to remove the water Xover and use a early one along with getting the port work to match the ports.I will have the intake made with RA IV size ports and location with enough material to make bigger.Tom
is anyone still making the 421 bathtub duel 4 bbl for a 62 b-body I would buy today.
  #566
Old 05-11-2025, 05:28 AM
The demand for the 61-64 heads was not that great.Im sure if you had a late style head on your your 62 as I do you could have a intake in short order.Tom
  #567
Old 05-11-2025, 07:40 AM
Do you have any suggestions where to go for a supplier?
  #568
Old 05-11-2025, 09:50 AM
These units were custom built.They were only sold by the maker.Innova Engineering in Santa Ana CA is the maker.John Cogger is a member on this site.He is making and selling the Pontiac underhood LS blower systems being shown on this site.Over the years there have been 3 reproductions on the Bathtub intakes.There was one for sale on this site,not sure if its still avail.Tom
  #569
Old 05-11-2025, 09:56 AM
Try this one
http://forums.maxperformanceinc.com/...Bathtub+intake
  #570
Old 05-11-2025, 01:50 PM
The early style intake had lesser demand and I think they only made 1 batch run of them on this particular latest project .
And that was it.
Those have all been sold now . And no more planned
The 65-up style , I think they made 2 batch runs.
And no plans to do anymore of those either.
Look for all the posts by member darbikrash to see the timeline of events.
You can post a "Want to Buy" listing in the various WTB parts sections.
But don't deal with any fresh-new members behind the scenes in private messages.
The newbies are usually scammers.
Fair Warning about due diligence.
  #571
Old 05-11-2025, 09:45 PM
JSuchma JSuchma is offline
PM sent
  #572
Old 05-12-2025, 07:28 AM
Tom
What would be the best late model heads for my 62 GP 421 if no 127 heads are used. What heads did you use. Thanks for all the info.
  #573
Old 05-12-2025, 01:10 PM
I run a set of 980s on my 63 421 Lemans with a Johnson-Zajack repo Bathtub,om my 62 GP I run 96 heads on a 63 HO block with the mule Randy Williams intake.It was originally a early style design.After we confirmed the fit we 3D scanned it and made a plastic intake to confirm the scan.I then sent it to Jim Robertson in TX and he converted it to a late style as Randy designed the casting to be used for early or late.Jim had to raise the ports .250 to mate with the late ports and also converted the water X over.Got it back,3D scanned it and made a plastic intake to confirm the fit.I then put it on my 62 with a pair of 62-63 Pontaic SD NASCAR 750 Carter AFBs.There are lots of late Dport heads that would work depending on CI.Good luck with your project.Tom
  #574
Old 05-12-2025, 01:55 PM
Tom
If your shortblock is already built , you might need to consider cam lift and which type/size of valve reliefs your pistons have.
You could run big valve heads up to a certain point of valve lift with small valve reliefs in the 421 style pistons.
Tom is saying he used big valve heads 1971 #96 , with 96cc chambers (if stock).
If he did a full fresh build -- he probably used new pistons with proper larger valve relief size.
  #575
Old 05-12-2025, 04:54 PM
Does anyone know of a 421 SD block that is serviceable. Had one that turned out to be unserviceable. Ready to buy immediately.
  #576
Old 05-12-2025, 06:46 PM
Why a SD block?Just get a nice 65 or later 421 or 428 block so you can use a block mounted starter.Buying a 421 SD block is just a complete waste of money.Or just get a good 400 block and use a aftermarket 4in stroke 3in main crank in it.Tom
  #577
Old 05-13-2025, 04:00 AM
Thanks Tom for the help
  #578
Old 05-26-2025, 07:00 PM
74GTONH 74GTONH is offline
Hi all - new to site. I still have a 1974 GTO since college '84, which now has 468 (bored and stroked 455) , 310 cfm ported Kaufmann D ports, Edeldbrock Performer RPM, 850 Holley Comp cam, M20 4sp, etc. I am interested if there's another production run of the 65 up style Pontiac 2 x 4 bbl bathtub intake.
Collected early SD parts since 84 - ported 544127 heads, 54299 2 x 4 intake, SD balancer - 62. Plan to use on 400 block ( 421 stroker) in future at some point.
Thanks !
Jim
The Following User Says Thank You to 74GTONH For This Useful Post:
  #579
Old 10-21-2025, 07:19 PM
63Acadian 63Acadian is offline
Default 1973 Acadian beaumont 462 Pontiac
4 years later I finally get to drive it!!! Runs awesome on my 462 with the bath tub intake. Its definitely a handful in a 2700 lb car w a muncie 4 speed.
ID:	659105   Click image for larger version
ID:	659107   Click image for larger version
The Following 8 Users Say Thank You to 63Acadian For This Useful Post:
  #580
Old 10-21-2025, 07:54 PM
433lemans's Avatar
433lemans 433lemans is online now
WOW! Nice. Great job.
