Old 03-17-2025, 09:12 PM
4dblnkldude's Avatar
Default Four speed brackets? Location?
I have two brackets that that I bought a while ago off a local poncho guy. I was told they are four speed brackets only. Apparently they only come on 4 speed cars. They are like a 14" piece of angle kinda flat on one end with a 1/2" hole on each end. Where do they bolt to?
The Following User Says Thank You to 4dblnkldude For This Useful Post:
Old 03-18-2025, 07:54 AM
HO LEMANS's Avatar
HO LEMANS HO LEMANS is offline
I'm guessing these are the ones you are referring to
NEVER DRINK DOWN STREAM FROM THE HERD
Old 03-18-2025, 09:24 AM
Yes! Thank you so much! They go in front of the rear, I though that they went behind.
Old 03-18-2025, 10:10 AM
HO LEMANS's Avatar
You are very welcome I just installed a set on my 67 Tempest, I had to do some looking to figure out how they mounted as well (more confusing than it should be) I just couldn't get my brain to look at them and say "oh yeah like this"
Old 03-18-2025, 06:30 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
Believe it or not. I pulled a set off of a 4 door Chevelle I found sitting at a Junk Yard about 30 years ago. Not a 4 speed car either.
Old 03-18-2025, 09:26 PM
I looked tonight and still cant see it. Yours looks like a 66-67? I have 69.
Old 03-19-2025, 05:26 AM
Scott Thelander's Avatar
66-7 are a little bigger/wider
but
the 68-72 mount the same
Old 03-19-2025, 07:49 AM
HO LEMANS's Avatar
The frame in the picture I posted is a 69 GTO (not mine although I wish it was) the 67 bars are different ... mount the same but look different.
Old 03-19-2025, 11:28 AM
gtohunter's Avatar
gtohunter gtohunter is offline
These are on a 68 frame...
Jimmy M
68 GTO
Old 03-19-2025, 09:09 PM
I'm missing something. I'll have to get it on the lift. I really appreciate the help!
Old 03-19-2025, 09:23 PM
Duh! I'm beat but went out. I see where they go.
Old 03-23-2025, 08:52 AM
android 211 android 211 is offline
I have a pair off 70 GP and another off a early Monte Carlo.
