Old 11-26-2024, 01:55 AM
Ramairnacho Ramairnacho is offline
Default The Se code
Originally Posted by F Body Freak View Post
Mine has that SE stamp like yours?
Sent from my SM-S901U using Tapatalk
I had mine restored and he made stamp made. I believe it's a pic code used at assembly plant but Im.not 100% sure. Your lucky to have that alternator they are very hard to find. I believe there in one for sale on py.
  #62
Old 11-26-2024, 02:29 AM
Here are the differences of an assembly line Carter - versus assembly line Rochester
The date code format , and the little c inside a circle.
  #63
Old 11-26-2024, 09:23 AM
Held for Ransom's Avatar
Both the Carter and Rochester QuadraJet's look very similar. OE will have a pick code (VB for the 7040264). Date wise Carter used a month/year (month=A to M, skipping I) whereas Rochester used a Julian date style (DAY/year, where day 001=Jan 1 to 365/366=Dec 31 depending on leap year).
Shown are two close to same build and a Carter replacement.
Your original carb. would have been dated in '69 probably.
ID:	643489   Click image for larger version
ID:	643490   Click image for larger version
So long, farewell.
  #64
Old 11-26-2024, 01:29 PM
Thanks guys!!!
Ya, it has other issues needing attention sooner than the carb. I've only drove it twice. About 10 miles home when I purchased it in early October, and this past weekend. About 6 miles down to the gas station & back. It seems to start right up & do what it's supposed to do. Kicks on high idle when it's cold. She's in winter hibernation now. Gonna tackle some things on it this winter. Re painting the rally wheels, new rubber, cleaning the engine compartment up to mention a few.
Thanks again, guys, and have a good Thanksgiving weekend
The Following 2 Users Say Thank You to F Body Freak For This Useful Post:
  #65
Old 11-29-2024, 10:52 PM
Here lately, my winter projects have been draggin into the spring & even summer, so i thought I'd get started on some this fall & get my buddy going with the sand blasting
They all 4 have matching codes
Dated
0 1 19
M1
JSClick image for larger version
ID:	643732Click image for larger version
  #66
Old 11-29-2024, 10:54 PM
20 original style lugnuts... I think around 5 or them had the plastic insert missing. They are black in color. Each rim had 1 of the longer nuts I show in the picture.
Is that something they did from the factory?Click image for larger version
ID:	643734Click image for larger version
  #67
Old 11-29-2024, 11:50 PM
No, aftermarket.
So long, farewell.
  #68
Old 11-30-2024, 09:35 PM
Dated
0 1 19
M1
JSAttachment 643732Attachment 643733
Interesting. Those are correctly coded and dated wheels for your car, which is surprising since the window sticker didn't show that it came with Rally II wheels. Would be very difficult to find those if you went looking. I wonder if the dealer might have put them on when it was new because the buyer wanted them?
Did you ever check the tail filler panel to see if it was metal or fiberglass?
  #69
Old 11-30-2024, 10:28 PM
. Did you ever check the tail filler panel to see if it was metal or fiberglass?
Question of the week.
Pertaining to the rear panel that surrounds the license plate.
Ransom meant the long lug nuts were aftermarket.
The ones with Black centers (lug nuts) are correct type for year.
And your actual center caps would be Red.
But they also make those in Black too - for earlier built cars.
  #70
Old 12-01-2024, 11:32 PM
Yea, IDK.
I thought they were on the window sticker, but it only says chrome wheel trim rings & F70 x14 white ltr polyglass. You would think it would almost have to be a dealer install when it was brand new.
I forgot to check for the pot metal piece in the tail panel. I'll look either this week or this coming weekend.
I plan on being in the trunk to apply some rust preventive paint to try & slow down the rust back there. It'll need a trunk floor & rear valance eventually, but I'd like to drive it a summer or 2 before that is tackled
  #71
Old 12-02-2024, 12:31 AM
Going out on the limb a bit maybe ...
But your car was built so early it was probably dealer inventory ordered.
Would have had the small hubcaps with trim rings RWL
The guy who bought it probably had the dealer switch the wheels from another new car on the lot.
He bought it on Feb 27
If you had PHS Invoice it would tell what day it was finished / ready to ship to dealer.
But it's not really needed with what you already have.
If the wheels were per se' ordered after the fact for dealer to install - they would very likely post-date the car by a bit.
Main thing is you have them and they don't detract value or looks from the car at all.
  #72
Old 12-02-2024, 10:38 PM
A magnet would stick to pot metal, right?
Magnet won't stick, & it looks fiberglass to me around the edges where the gas cap sits in thereClick image for larger version
ID:	643897Click image for larger version
  #73
Old 12-06-2024, 09:05 PM
Magnet won't stick, & it looks fiberglass to me around the edges where the gas cap sits in thereAttachment 643897Attachment 643898
Actually, no - a magnet will not stick to pot metal.
But if you see white fiberglass edges somewhere, that would be a tell. You might look up at the top of the opening where the license plate lamp mounts, too. Sometimes easier to see the edges there.
  #74
Old 12-10-2024, 10:02 PM
Don't see any white edges. Looks to be black under the yellow paint. The edges around where the license plate light is cut out, feel like plastic. IDK. If I was guessing, I'd say it's fiberglass Click image for larger version
The Following User Says Thank You to F Body Freak For This Useful Post:
  #75
Old 03-31-2025, 04:07 PM
Hello all. Been plugging away this winter on some issues. Had good weather this past weekend, so brought her out of hibernation. Changed the fluids in the engine & rear diff. Coded the axle out to a 3.07 gear, no posi(or safety trak?) Im still a Chevy guy, lol. Detroit Axle, late Jan/70 build date.New Transmission filter. Redone the rims, new center caps & tires. New Bilstein shocks took the rear squat away. Knocking the to do list done. Still have the engine compartment to clean upClick image for larger version
  #76
Old 03-31-2025, 04:18 PM
Also took the rear glass out to address the leaking window... Its not pretty, but I knew it wouldn't be. Found a place that makes replacement channels to weld in there. Plan on tackling this in the next couple weeks. Welding them in will mess up the paint back there, but i think its the best way to fix it "right" Paint has many flaws. Car has been repainted. It was close to needing the drivers side quarter & roof replacement. Crazy how much rot a leaking window can cause. Holes in the trunk pan from it tooClick image for larger version
ID:	649684Click image for larger version
ID:	649685Click image for larger version
ID:	649686Click image for larger version
  #77
Old 03-31-2025, 07:17 PM
7t4mula's Avatar
7t4mula 7t4mula is offline
Yes, that rear window channel rot is pretty common, especially with vinyl top cars like mine was. Totally rust free CA car except for that area. My body guy took care of it nicely!
ID:	649701   Click image for larger version
  #78
Old 04-01-2025, 12:39 PM
That looks good. Hopefully, mine looks like that soon
  #79
Old 07-01-2025, 04:34 PM
A buddy got the rear window rot replaced. Made pretty short work of it, actually. Wife works the whole holiday weekend, so I plan on getting some paint on it(just gonna spray bomb it) & give the interior a good cleaning & put back in. Hopefully driving her soonClick image for larger version
  #80
Old 02-17-2026, 05:48 PM
Here's my original thread...
I should've just posted questions about the water pump here. Hopefully I get the picture thing fixed & can give some new updates here.
