Old 04-09-2025, 12:40 AM
58cheaptin 58cheaptin is offline
Default 1963-1966 Front Crank Seal Question
I am currently doing the timing cover modification on my '58 Chieftain to allow for a '63-66 front crank seal to be used instead of the older-style cork and spring washer style that is original.
I'm curious to know if they ever made this front crank seal with a flange on it to use or is the standard style the only option? If they did make one with a flange, does anyone happen to have a manufacturer and part #? The National part # for the standard one is #332062 or GM #544452.
Any help is greatly appreciated!
Thanks!
Old 04-09-2025, 04:45 AM
Why is it you want one with a flange?
Are you taking about having a flange on the balancer side?
Old 04-09-2025, 02:28 PM
From what I can tell with the two part numbers you listed those are for 67 and up motors and have no flange .
My guess is they have no flange because the newer timing covers had a internal lip that stops the seal from being driven in too deep, and this means they do not need a flange.
Old 04-09-2025, 04:24 PM
madeuce50's Avatar
madeuce50 madeuce50 is offline
TCS133833 Felpro timing cover gasket set does have a flanged crank seal. Sorry, I do not have the number for just the Felpro seal in the kit.
Old 04-09-2025, 05:03 PM
If you get your hands on the box that the fel pro TCS set comes in I believe it will list the part number of the seal on it.
Old 04-10-2025, 08:59 AM
madeuce50's Avatar
Nope, current kit packaging does not list any part #'s for contents like the boxed kits from bygone days used to..... that would be too easy.
Old 04-10-2025, 09:41 AM
Yes, the top end set I have sitting here is a pretty old one, I was hoping.
