Old 03-14-2023, 11:37 AM
Elarson's Avatar
Elarson Elarson is offline
Originally Posted by aaronman View Post
Congratulations on a well designed and executed build. Thanks for taking the time to share it so we can all learn.
Sharing what we learn (both good and bad) is a big deal to us. We all need to get smarter together. Mike and I pay attention to everyone else's builds and have learned from them. It's very much a 2-way street.
Eric
The Following User Says Thank You to Elarson For This Useful Post:
  #62
Old 03-14-2023, 03:27 PM
sdbob sdbob is offline
Thank you for the info. I'm another one who looks. Wonders why someone is doing certain things. I've read reread alot of articles. Have Herb Adam's book on 'Chassis Engineering'. On my 73 F drag car I modified the front spring perches according to Herbs ideas trying to increase anti squat.
  #63
Old 03-14-2023, 04:57 PM
Sounds like a nice setup. What gears in the 9"?
  #64
Old 03-14-2023, 09:02 PM
Elarson's Avatar
3.55. Should be good for about 140 mph at 6500 in 4th
Eric
The Following 2 Users Say Thank You to Elarson For This Useful Post:
  #65
Old 03-14-2023, 10:40 PM
Seriously with 3.54:1, the OD allows my combo to do 2500 @75, but the standing pull from 65 to 90+ mph is like the pull of a 1/4 mile run, actually the butt and other cognisant cars make it compelling to suggest;
If you got a 455 in a road race, you might want to reach for an OD gear shift.
  #66
Old 03-15-2023, 09:40 AM
Eric
Should be a good combo. Always like cornering , autocross my 78 with road race slicks for quite awhile.
Back when my '78 TA had the stock 180 HP motor TH350 took it to a track day at Texas World Speedway with the Porsche Club. With the 2.56s I could run most of the road course in 2nd, but on the long straight the motor would only pull 4000 and that was all it had-still 130mph And the stock springs at that speed felt like Grandma's Cadillac over bumps! Way soft.
  #67
Old 03-15-2023, 12:45 PM
3.55. Should be good for about 140 mph at 6500 in 4th Eric
Agree! Engine should easily be capable of many 140 MPH / 6500 rpm (4th gear) pulls in a 20 minute session, based on the description of the build.....
Between Skip, Myself, and now you, Eric, there is not much Road Race
experience out there.
  #68
Old 03-15-2023, 01:44 PM
Elarson's Avatar
Gordon S. ("HO428" on this board) was a lot of help when I started this project but doesn't seem to post any more.
Eric
  #69
Old 03-15-2023, 06:04 PM
blueghoast's Avatar
Eric
Yea wonder what happen to him, Been a long time since he posted.
Nice build by the way, Should be a lot of fun.
GT
  #70
Old 03-15-2023, 06:12 PM
blueghoast's Avatar
Hey sdbob could you elaborate on the anti-squat I'm not sure of what
it really means and I too am trying to learn all I can.
Didn'tmean to hyjack sorry.
GT
  #71
Old 03-15-2023, 07:05 PM
JLMounce JLMounce is offline
GT
Anti-squat and anti-dive references moment of inertia points on the car transected by suspension pickup points.
Here is a good read on the subject. https://suspensionsecrets.co.uk/anti...lift-geometry/
anti squat would be the tendency for the rear of the car to resist compression. Why you want this in a road race situation is the fact that as the rear squats, while it does add traction at the rear, it unloads the front, reducing traction on your steering tires. this will typically result in a tight exit on power from the apex.
Anti dive does the same thing, but at the front of the car under braking.
-Jason
1969 Pontiac Firebird
  #72
Old 03-16-2023, 09:27 AM
Elarson's Avatar
I always wanted to road race always(Herb Adam's ,Chaparrals). Drag was cheaper.
ELarson are you running leaf spring rear suspension? I still have that 74 good TA shell.
Are you pondering a new project? Curious minds want to know......
Eric
  #73
Old 03-16-2023, 11:02 AM
Yes you know the mind thinks I can. Taking that 74 shell and using it for a road race car using Herbs ideas. Problem $$$$ for the needed dry sump(I just think it is insurance but probably not needed),then the best brakes(when i was young didnt think much about them other than they are there), then the engine best parts$$$$. So car body may go down the road. I have the original 74SD TA, the put together 73 SD drag car,a 10k 67 400 4spd ,4.33,RA. Firebird. And my sitting 63 Lemans,(326 3spd long gone) project. 57 olds,400 m40. At 75 I'm seriously thinking selling the shell.
  #74
Old 03-16-2023, 06:04 PM
Herb Adams and Tom Nell did stuff for reasons. PERIOD.
They installed a Cheater oil pan/ Dry Sump Tank/and Camshaft Driven Oil Pump in the engine and F-body.
If you have never had any road race track time on a vehicle ), your money might
be better spent on your other "collection" vehicles. The Vega/Astre body would not be my 1st choice for that adventure.
  #75
Old 07-23-2024, 04:13 PM
Elarson's Avatar
It's been awhile since the last update. Engine and transmission are finally in the car. Wilwood manual brakes are installed, plumbed and bled. I had an adapter plate made to solve the problem of the missing accessory mount hole on the hi-port heads. Next step is wiring and plumbing. Then build a custom air filter housing for the shaker scoop.
Eric
ID:	637316   Click image for larger version
ID:	637317   Click image for larger version
ID:	637318   Click image for larger version
  #76
Old 07-23-2024, 04:38 PM
Dragncar Dragncar is online now
Nice, that missing bolt on High Ports can kinda be a issue. I wish they had it in.
I am using the stock alternator adapter like you are. What I did was drill and tap a hole in my 3/8" thick elephant ears to get it done.
I wonder why KRE deleted it.
  #77
Old 07-23-2024, 04:56 PM
Elarson's Avatar
Jeff told me that they had to move the water jacket and it got too thin to tap a hole there.
Eric
  #78
Old 07-23-2024, 04:57 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Looks good Eric. I noticed you have a heater hose block off cap on the timing cover. Not sure if you have a use for that fitting but if not it can be tapped for a 3/8 pipe plug.
Everything looks great!
Go fast, see Elvis!
  #79
Old 07-23-2024, 09:57 PM
Elarson's Avatar
Good idea. I don't fully trust the rubber caps.
Eric
  #80
Old 04-12-2025, 10:05 PM
Elarson's Avatar
The Firebird is finally on the road today. Open headers so all the neighbors could experience it with me. This thing is rowdy! Gobs of torque, even off idle.
It still needs work...exhaust system, parking brake cables, front alignment, adjust front ride height up a little. It's up on the lift now.
Eric
ID:	650199   Click image for larger version
