Old 04-17-2025, 10:39 PM
Bricker1970gto Bricker1970gto is offline
Default 1970 gto judge
I’m currently in the process of restoring my late father’s 1970 gto judge. I have the body off the frame doing the body mounts. I’d like to restore it to the most original I can. There is currently a Rochester quad jet carb on it. Where would I find the number on it? What carb should I put on it with the proper intake to be able to put the ram air back on?
ID:	650460   Click image for larger version
Old 04-18-2025, 12:33 AM
Here is where to find the carb ID number.
This one is 7040273
Old 04-18-2025, 12:36 AM
Cylinder head ID number , in between the center spark plugs.
These are number 12
Old 04-18-2025, 12:39 AM
Engine block ID code
Located on passenger side front - in between cylinder head and timing cover.
This one is WS
Old 04-18-2025, 12:43 AM
Engine block partial VIN (verifies original born with engine)
Located on passenger front - down low next to timing cover - below the radiator hose outlet.
This one is 20R147181
Old 04-18-2025, 12:45 AM
All of these pictures are from a numbers matching 70 Judge with 4spd Transmission.
Old 04-18-2025, 07:33 AM
The casting number for the intake is 9799068.
Old 04-18-2025, 01:51 PM
Looks like you have an aluminum Edelbrock dual plane intake.
It should work okay if that's what you want to use.
If you want to buy a 1970 cast iron intake like factory , John supplied the casting number.
They also have date codes cast in them next to thermostat.
If you have a choice , you would want to select a date code that predates the car build by a short margin.
Your carb looks to be a side inlet Chevy.
Pontiac , Olds, Buick fuel line comes straight out front.
Not sure that fuel line arrangement will work with the RA pan.
but maybe it will
The factory correct numbered carbs are extra expensive now , and not required.
Here's a link to a very original / correct 70 Judge with some pictures , that just sold.
https://bringatrailer.com/listing/19...ge-4/#comments
Old 04-18-2025, 07:02 PM
If you are getting email notices about replies to your thread - but can't find it in the Lobby
- they have moved it to the 69-71 Judge section of the forum.
