Old 04-22-2025, 07:19 PM
gtorich gtorich is offline
Default Windshield trim
Getting ready to install my windshield trim on my 66 that i had buffed, i was missing a clip or two, got new ones was wondering do i throw some right stuff on the clip, all the others seem to have something holding them down.
Rich
Old 04-22-2025, 10:15 PM
They should fit tight to the sheet metal without anything holding them down.
Old 04-23-2025, 07:51 PM
Hey goatracer, thanks for the reply, i got the two of them on, but it seems they are really close to the top of the windshield, seems like they should bend a little on the top, i messed around a little today , not sure i can get the trim behind the two new tabs...........was wondering if i squeeze the clips with my windshield tool will they bend a little and then i can push the trim on...............dont want to go caveman on the stuff beating it on like i see on some vids..........
Rich
Old 04-24-2025, 08:40 PM
Ok, heres where im at today, put the clips i got from ames on, there is no way i can get the trim to fit, the clip is tight against the body, very hard to get them on the stud, have to hit with a hammer to fit on the stud. My old ones go on by hand easy but i only have 6 of them, two clips were missing when i took the trim off, not to happy losing paint putting these clips on and off. The old ones seem bent forward while on the stud, on the new ones there is no way possible to push the trim on. Anyone have a different clip to buy, the ones from ames are 3/4 wide by 5/8 high.........took some pics with the phone, hopefully they come out ok,
Also i have 15 of these plastic clips on the trim, do i need these, seems the stuff is touching the glass anyways. The sides and bottom all fit good, the top is bad.
Rich
Name:	Windshield trim (1).jpg
ID:	650745   Click image for larger version
Name:	Windshield trim (2).jpg
ID:	650746   Click image for larger version
Name:	Windshield trim (4).jpg
ID:	650748   Click image for larger version
Name:	Windshield trim (3).jpg
Old 04-25-2025, 08:24 PM
In case anyone is following this, i got one of the clips from ames to work today, in the 3rd pic above you have to bend the clip that goes on the stud back quite a bit, so far i got that one to work, broke about 3 others trying this, seems you have to bend them while on the stud, little nervous doing this, worried about breaking the stud.
So is this the way you guys are getting these clips to fit, or is there a better way to do this.
Rich
Old 05-27-2025, 01:15 AM
SD421's Avatar
SD421 SD421 is offline
Did you check the spacing?
Scroll down to glass setting info
http://https://www.rustreplace.com/h...tips/downloads
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 06-07-2025, 07:30 PM
Forgot to add, got everything on, took awhile to figure it out, but looking good now, thanks for the help guys
Rich
The Following User Says Thank You to gtorich For This Useful Post:
