Old 05-30-2025, 12:06 AM
unruhjonny's Avatar
My other door decal I have here is I believe from an Oshawa car;
A 1970 Lemans which was in the scrapyard a couple years back - it’s definitely a different font than that used in Norwood for the same year.
EDIT:
I will add that these are REALLY tough to get off in one piece, or nearly one piece… which is why I only have two.
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
Old 05-30-2025, 07:11 AM
mrennie's Avatar
mrennie mrennie is offline
The 3, 6, and 9 in those Oshawa labels are very unique.
Michael
1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished!
1979 Trans Am - low-buck drag car project for when I retire
Old 05-30-2025, 12:27 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
As has been stated, the IBM Selectric typewriter standard font is a good approximation - IBM made most of the printers and computers in this era so that makes sense. My Fremont 1972 Lemans needed one 25+ years ago and that was what I used. When I used to repair them for the junk man back in the '90s you could get them cheap and I also found that the typeface head was quickly and easily replaceable with different fonts that were available from IBM. I would hazard a guess if you trolled sales or found a weirdo who likes old typewriters they could easily locate the type heads with the various fonts.
Finding something modern that approximates it is something that nerds have done for other fonts - namely Gorton (link) among others.
Edit to add: This guy right here (click) has a wide variety of font balls and examples of each. I bet if it was ever made by IBM you'd find it there...
