Old 07-21-2025, 12:55 PM
ebartone ebartone is offline
Originally Posted by GOAT8U2 View Post
Clearly 60ft here is your loss in ET, actually if you get your 1.7 back you'll be faster.
Are those 275 dead hooking?
You might need to leave higher, 3200rpm etc and take advantage of this tire hooking and higher rear torque gear multiplication.
https://tiresize.com/gear-ratio-calculator/
Your 3.36 on a 27" tire was the same as 3.48 vs your new 28" tire on 3.70.
What's your rpm through the traps now vs before?
Your converter is at best coupling 3".
Thanks - I'm not completely sure if it is dead hooking, sorry if that sounds novice. I recall one launch last year that was an actual head snapper, and I've never felt that since, maybe it's a "if you have to ask, it's probably not". I have my tires at 20 lbs. and my single adjustables at 2 (of 16) but have moved both all over the place with little difference. Last year I launched at pretty good RPM, I'm trying now to come just off idle to be more gentle. I've had a video of a run this year, and I'm sure I saw white smoke like 30' down the track at the wheels.
