My previous 4.210 stroke 462 combination made peak power on the dyno at 5800 rpm (580 hp) and we used a 6200 rpm chip in the shift light.
I can assume it was closer to 6000 rpm (?) There is reacting to the shift light and the physical time to make the shift. I have a time slip for a 1.6 60-ft and 10.88 at 124.28 mph. Again for conversation only, but entering the numbers into the calculator I posted works out close: 28 inch tire (88" circ.) 6000 rpm 3.73 gears in use (TH400 trans) 6.7 Torque Converter Slip (%) 124.28 mph That amount of converter slippage the calculator indicates is not out of the question for the converter at the time. I sent my dyno sheet and car specs to Marv Ripes at A-1 and he built a custom 8-inch unit for us. It had about a 4200 rpm stall. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 07-21-2025 at 04:15 PM. |
| The Following User Says Thank You to Steve C. For This Useful Post: | ||
