Old 05-02-2007, 05:38 PM
cheapheat cheapheat is offline
Default 70 -Dual or single snorkel? does plant have anything to do with it?
I know I have searched the forums before and was convinced that 70 T/A's are supposed to be single snorkel but I still read other places it was dual.
I have a blue on blue 30,000 original that came with a dual and I have a 71 that needs a dual air cleaner.
I find it hard to believe that someone lost the single and searched at length and found a double for my 70, and I have seen others with the dual.The dual I have still has the GM part # sticker on it. Is it possible that cars from different plants got different air cleaners? Mine was a complete dip in red oxide. Is it easier to make a single and that is why some have a single instead of paying top dollar for a dual?
Old 05-02-2007, 06:08 PM
68bird400HO's Avatar
1970 RAIII TAs had a single snorkel. RAIV TAs has the dual snorkel. In 1971-72, all TAs had the dual snorkel. All 1970-72 Formula 400s and 455s without ram air also had the dual snorkel. The formula bases are easily converted to TA bases by adding the tabs for the shaker and the hose ring (for lack of a better name) on the bottom side of the passenger snorkel.
The Following User Says Thank You to 68bird400HO For This Useful Post:
Old 05-02-2007, 06:13 PM
I am assuming the single snorkel would be the wider one and not the smaller opening?
Old 05-02-2007, 06:51 PM
the snorkel on the single snorkle is the same as the ones used on the dual snorkel units.
Old 05-02-2007, 09:28 PM
Agree there seems to be the occasional '70 RA III T/A with a dual inlet air cleaner on it, but at least 9 out of 10 are single. Don't know why some are dual... could have been built that way, or possibly replaced over the years.
Old 05-05-2007, 07:40 PM
Originally Posted by cheapheat
...The dual I have still has the GM part # sticker on it...
Having that sticker would make it an over the counter replacement part - not an assembly line item. Things do get replaced/upgraded on even the nicest and most original lowest mileage Cars in existence. 1000 guesses and might still be wrong answer as to why or when.
Look on the bottom of each snorkel. If only one snorkel has a heat riser mounting provision - it's for a non-Ram Air Formula. If both snorkels have the provision - it's either for 70 RamIV or 71/72 455 HO.
Back in the days when every detail didn't matter so much - a dual snorkel was the preference of most owners. Very little difference in the market value of a TRUE single snork 70 TA base, and dual snork base. I actually notice more duals on the market than singles.
Old 07-21-2025, 05:43 PM
georgeta70 georgeta70 is offline
Default dual snorkel for 70 T/A
Hi Baron,
I have seen your many comments on early TA's and am hoping you can find me a 70 T/A specialist in the SF Bay Area. By the way, my survivor 70 Ram III has a dual sonklel. Thanks,
Please call me 415.613.3161
Old 07-21-2025, 06:33 PM
Originally Posted by georgeta70 View Post
Hi Baron,
Hello George and welcome to PY Forum.
70 Ram3 TA would be a single snorkel .
70 Ram4 TA would be dual.
There were quite a few versions of dual snorkel , but yours would have to be from a specific Formula or TA car , to fit under the hood.
GTO and G.Prix versions don't sit low enough.
This one I am picturing is from a D-Port engine.
Notice that the driver side snorkel has an attachment point on the underside for a heat riser tube that comes the driver side exhaust manifold shield.
Passenger side does not.
The 70 Ram4 TA , and 71-72 TA were RoundPort engines.
They had an attachment point on the underside of BOTH snorkels.
RoundPort engines had an aluminum factory intake with a separate cast iron exhaust crossover in the mid section.
That separate crossover had a shielding over it , and on the passenger side there was an attachment point for a second heat riser tube that attached to the underside of the passenger side snorkel.
RoundPort engines had 2 heat riser tubes , one on each side , each snorkel.
Dport engines just had 1 heat riser tube on driver side.
If yours has attachment points underneath on Both Snorkels - it's 71-72 TA
Only on 1 Snorkel - it's from 70-72 Formula
Old 07-21-2025, 06:41 PM
Also , I am in North Carolina.
We have good members on here in Cali , but I'm not sure who is in the Bay area.
You can start a new thread for your car by itself , and many people will be glad to answer questions.
You could also ask in your new thread if anyone is in the Bay area , if there are things you need another set of eyes on in person.
I circled what you need to look for to start a new thread about your car on this screen shot.
Welcome aboard !
Old 07-22-2025, 01:04 AM
unruhjonny's Avatar
unruhjonny unruhjonny is online now
It is mot not my intent to come off as contrary;
I thought I read from reputable sources that although most 70 RAIII T/A’s left the factory with single snorkles, some legitimately had dual snorkles?
I would think that:
dual snorkle + single heat riser + shaker tabs = legit RAIII dual snorkle.
Maybe I am misremembering that some ‘70 RAIII T/A’s had RAIV shakers from the factory??
1970 Formula 400
Old 07-22-2025, 10:25 AM
muscle_collector's Avatar
one of my 70 ta's that i bought around 1980 from the original owner had a dual snorkle on it. i asked him about it and he had no idea just said that was what was on it when i bought it off the dealers lot. possibly a date thing??? ive owned over 25 70 ta's over the years and have seen them both ways, but most ra3 have had the single.
The Following User Says Thank You to muscle_collector For This Useful Post:
Old 07-22-2025, 10:53 AM
Thanks fir that.
Old 07-22-2025, 11:00 AM
I recently bought 70 TA from a 46 year owned reputable owner and he told me that the double snorkel was true to the car.
Old 07-22-2025, 11:01 AM
thanks
Old 07-22-2025, 11:05 AM
Hey Baron, thanks for that picture, will check when I return home, by the way, I discovered you on BAT.
Old 07-22-2025, 12:20 PM
Will my double snorkel air cleaner have dates/numbers that will match the car?
Old 07-22-2025, 12:38 PM
It will have an ink stamp date code on the inside or the bottom.
I forget now exactly .
In the 80s we were putting 71-72 dual snorkel pans on 70 TAs for the look.
Still have one on mine.
Everybody would rather have the dual snorkel for looks.
These days originality mean more.
If one was done at a plant as a goof , then it was a goof.
Have never seen a nice original well kept 70 Ram3 TA with a dual.
Always a single.
Never seen a dual with a single heat riser and factory tabs.
This late in the game I wouldn't trust anything , the tabs have been repopped.
Old 07-22-2025, 01:02 PM
Hi baron I sent you a message
Old 07-23-2025, 09:05 PM
George I sent an email to your @gmail address.
Old 07-23-2025, 09:58 PM
In restoring these bases, I have always examined the spot welded on tabs on questionable '70-72 TransAm shaker bases to see if the tabs were factory installed with small spotwelds, brazed on, or sloppy spotted with a MIG.
A thought... quite a few single heat riser dual snorkle Formula bases have been made into T/A bases over the years. I've only examined one factory dual snorkel T/A base with a single heatriser that had factory tabs which did not appear to be effed with. Very uncommon to run across such a shaker base, nearly all of the '70 TransAm bases I've repaired or restored were single snorkel original RA III bases, two were RA4 T/A bases.
