Old 08-01-2025, 04:28 AM
Squidward's Avatar
Originally Posted by JLMounce View Post
These just hit the market for 67-69 F-Body owners as well.
https://fastmontysgarage.com/the-sho...ed-gloss-black
I saw those. And in the process of watching some Fast Monty last week, I saw him test a Proform brushless fan rated at 3400 cfm.
I liked the soft start, and it has a nice low profile. So I bought a straight blade 16" fan. I'm gonna mount it on my radiator as a puller, and see if I can run it inside my shroud with a mechanical flex fan running off the water pump (if clearances allow). I should be able to make an easy comparison between the two fans stacked in series, or just the electric.
https://www.summitracing.com/parts/pro-67036
This will make my electric circuit easy, with dc circuit breaker/fuse and a relay triggered off the FiTech and the ac clutch. The FiTech triggers a ground signal for the relay coil, and I will have to use another relay to provide a ground when the ac clutch turns on, like an inverter.
