#81
#82
Put me down for a set. I'll send you an email.
I'm going to pick up my new '63 Le Mans tonight! Woo Hoo!
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind, E85 Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
#83
#84
The brackets arrived Thursday. Thanks Jim!
So who has the best prices on the whole Wilwood set up? Summit? Jegs? 2)Earl's#63010114 flex line 2)Earl's#961603 pipe to AN adapter 2)Earl's#989543 tubing adapter 10) Mr. Gasket#4311 studs 1)Strange Engineering#B3359 master cyl. 1)Wilwood#140-0261B brake kit
#85
Anyone know if the Wilwood pro-street kit will fit these brackets also? Will they clear a 15x4 front wheel? Jegs Kit # 950-140-2115-B Summit kit #WIL-140-2115B
--> Jegs <-- --> Summit <-- Larger 12.19" rotor vs. 11.44" for the drag kit. .810" rotor thickness vs. .35 thick for the drag kit. Sounds a bit more street friendly. If no one has tried them, looks like I'll have to be the guinea pig. EDIT: Nevermind - Adapting to the bigger rotor will throw off the caliper holes in the custom brake brackets.
#86
I have them on 2 cars,first set went on over 6 years ago and still on the same pads.Have the gator pads but they have been replaced.Will find the replacements.When I did the wagon I ordered a Xtra set of pads.Tom
#87
I have a spare set of these brackets which I will never use. If anyone is interested, contact me by PM.
#88
I want a set of discbrake brackets. Where do I send money? How much? Email me here.Thanks Bob.
#89
My 63 probably been down the strip 150+ times. Gets stopped from 116-118 mph. Just have the standard wildwood setup. Never changed pads and even drive on street with the stock single master cylinder. Made my own brackets but got to be the same as Jims.
#91
need a adapter plate for 63 pontiac tempest front
