1982-92 TA & FB TECH 1993-2002 TA & FB Tech is now part of the new Late Model Section of the PY Forums. Click this link to check it out.
Old 05-30-2017, 10:56 AM
mrrat1 mrrat1 is offline
brought it home Friday........brake pedal is very soft, could be the lack of vacuum. I have a few little things that need to be done. Locks are all stiff from aged lube. Needs stereo speakers. I have to replace a cracked ground effect on the rear bumper I have an NOS one. Needs the air deflector under the front bumper. A real good clean up on the interior.
When the tags come I'll be making trips for estimates on paint & body work. Hopefully I can get it done this winter.
  #82
Old 05-30-2017, 01:56 PM
ponyakr's Avatar
ponyakr ponyakr is offline
"...could be the lack of vacuum..."
Yeah, I can't imagine a CC 292 Magnum makin much vac.
  #83
Old 05-30-2017, 02:58 PM
marxjunk marxjunk is offline
in 83 at the car craft nationals, there was a white T/A, a brand new one..with a 455SD in it..with a rock crusher...really done well and looked right...too bad GM didnt try a traditional pontiac engine in there for awhile before they went to the corporate idea
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
  #84
Old 05-31-2017, 10:57 AM
Brakes will have to be addressed. Very happy overall though......The engine is quite responsive, but needs exhaust work. The 2 1/4" head pipes are a big restriction, even with the empty cats. I can see lots of rear tires in my future! LOL
  #85
Old 06-14-2017, 04:51 PM
latest pic
Name:	1984 Trans am side view.jpg
  #86
Old 06-16-2017, 09:00 AM
QQ plates arrived did the first shake down.....car runs great but need the lower air deflectors! The temp went to 220 then 260 pretty quick. I have a set coming from E-bay should have them next week.
  #87
Old 06-27-2017, 12:17 PM
TTOP350 TTOP350 is offline
This is sooooo cool. makes me want to do what gm should have
http://www.fquick.com/garages/viewga...ewimg&id=74990
"You people have stood in my way long enough. I'm going to clown college."
-Homer Simpson
  #88
Old 06-30-2017, 09:25 AM
Thanks.......still lots to do! Hard stuff is done & I can at least drive it now!!!
  #89
Old 07-31-2017, 02:32 PM
Installed the lower front air deflectors....car ran hot 240* & blowing coolant without it.
Have some interior pieces to install, bleed the brakes again.
  #90
Old 10-01-2017, 10:44 AM
soupman soupman is offline
Have you done anything more to car? Any lessons learned on the swap you would do different next time around? I am thinking of doing the same thing but keep my 700r4 with adapter plate.
  #91
Old 10-04-2017, 11:25 AM
Haven't messed with it lately........Can't think of anything I would have done different.
I did use the 700 trans but upgraded to the 30 spline & used HD internals. I have a lock up converter on a switch. Some say go with no lock up. I can't say either way as I don't have any miles on it yet. Still have to get the head pipes redone. They are orig and on the small side.
  #92
Old 08-19-2025, 03:18 AM
Harold Washington Harold Washington is offline
Has anyone used a header with a pontiac400 in 84 ta
how455
