I’ve cobbled together hardware store fittings (at oil filter adapter) to have both an oil pressure gauge line and the factory idiot light sending unit. I don’t like the look of it. Is there a simple bushing that has a male fitting to screw in (and seal up) at the filter adapter and has two female ports that the gauge and sending unit can screw into (and seal up)?
The link shows what I’m trying to achieve… https://firstgenfirebird.org/forums/...pter%20004.jpg |
See if you have the room to use another 1/8” hole that you drill & tap into the oil filter adapter.
Then you might only need a 45 or 90 degree fitting / adapter to get things plumbed up. If this is too much work then you need a male 1/8” pipe T fitting block that goes to a female 1/8” at each end.
Use the NPT hole next to the distributor for your oil pressure gauge and you won't need any adapters coming off your oil filter housing.
1967 Firechicken, 499", Edl heads, 262/[email protected]" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. [email protected] mph with a 1.45 60'. Still WAY under the rollbar rule. |
