Old 09-13-2025, 01:05 PM
bill ryder's Avatar
bill ryder bill ryder is offline
Default 65 wiper arms appearance
Just curious, when did the wiper arms change from shiny to brushed in appearance? Was it sometime during the 65 year or not until the 66s came out?
THANKS
"Bill"!
Old 09-13-2025, 01:36 PM
gokitty gokitty is offline
67s were bright. 68s were dull.
bill ryder's Avatar
And while on the wiper subject, is it known that the wiper motors case was either steel OR aluminum. Just FYI.
"Bill"!
Old 09-13-2025, 04:10 PM
242177P's Avatar
242177P 242177P is offline
Disagree. 67s had satin wiper arms. Interior rearview mirror too. 66 still had the brightwork.
Old 09-13-2025, 05:28 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
My experience after 50 years of collecting factory Original GTO cars and parts.
1964 and 1965 GTO’s came with bright polished stainless steel arms and blades.
Below are the Original arms and blades that came on my ‘65 Survivor.
ID:	657088   Click image for larger version
ID:	657089   Click image for larger version
The Following User Says Thank You to 60sstuff For This Useful Post:
Old 09-13-2025, 05:34 PM
60sstuff's Avatar
1966 was the first year of the brushed wiper arms and blades.
My ‘66 Survivor came with the non glare brushed finish.
ID:	657092   Click image for larger version
ID:	657093   Click image for larger version
ID:	657094   Click image for larger version
The Following 2 Users Say Thank You to 60sstuff For This Useful Post:
Old 09-15-2025, 10:32 AM
bill ryder's Avatar
Thanks Chris. That is what I remembered, BUT I was not sure if it might have started on the late 65 model.
Thanks to all!
"Bill"!
Old 09-16-2025, 07:44 AM
Andre's Avatar
Andre Andre is offline
I believe that it was one of the many things that appeared in the 1967 model year safety changes such as:
brushed wheel trim rings
Collapsing steering column
front seat belts with integrated retractors
four way safety flashers
rubber trim around inside rear view mirror.
... and a bunch of other things that I don't recollect. California being a different kind of animal may have been earlier than the nationwide mandate.
Old 09-16-2025, 04:00 PM
60sstuff's Avatar
My observation over 50 years of collecting GTO’s.
I agree that 1967 (Pontiac Tempest Series) brought on protective rubber (rubber trim around the inside rear view mirror and mounting bracket base, plus rubber knobs on window cranks).
BTW, 1966 was first year for padded sun visors.
Besides being the first year for collapsing steering column with integrated safety flashers, there were the front seat back push locks.
Also first year for optional shoulder seat belts.
Some items that were already available in earlier years.
Brushed wheel trim rings were on the 1965-66 Rally I wheels.
Also front seat belts could be ordered with retractors in ‘65-‘66.
California had nothing to do with safety changes made (except smog) in these cars as it was mandatory from all plants.
I have several factory Original example GTO’s in my files showing brushed wiper arms / blades from other factories in 1966,not just Fremont.
Old 09-17-2025, 04:51 AM
Kenth's Avatar
Kenth Kenth is offline
Shoulder front seat belts came available 3/1/1966.
Also, an odd California regulation on 1966 rear stop and turn signal lamps!
Name:	1966 Shoulder Strap.jpg
ID:	657279   Click image for larger version
Name:	Instr. 1966 shoulder straps.jpg
ID:	657280   Click image for larger version
Name:	1966 stop and turn signal lamps.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 09-17-2025, 09:48 AM
60sstuff's Avatar
The provisions (anchor nuts) were installed for these shoulder belts in ‘66, but I’ve never seen any that year.
PHS in 1967 shows Shoulder Belts, Front Seat code #434, and I have seen this rare option on a couple ‘67 GTO’s.
Also another interior change in ‘67 were the coat hooks made of plastic.
ID:	657292   Click image for larger version
