Old 09-23-2025, 02:19 PM
Longs's Avatar
Longs Longs is offline
Well now at 2:20 p.m., 50 minutes after my post above, 835 users online, 50 of which are members.
  #122
Old 09-23-2025, 03:56 PM
KS circutguy's Avatar
Sure beats 12,000.
  #123
Old 09-23-2025, 04:11 PM
sdbob sdbob is offline
I thought it was me. When comparing what you guys experienced its same here. I've noticed bad or not good advice on you tube , net,etc with our Pontiacs. This forum is the best for help,experience with building our Pontiacs.
  #124
Old 09-23-2025, 05:53 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Way way better, only 189 guests now and similar when I popped on 3 hours ago, good job on making them aware and the quick fix after.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
The Following 2 Users Say Thank You to GOAT8U2 For This Useful Post:
  #125
Old 09-23-2025, 06:25 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Looks like they took out the trash.
  #126
Old 09-23-2025, 09:37 PM
Cammer-6 Cammer-6 is offline
A big thank you to staff for the improvement
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
The Following 3 Users Say Thank You to Cammer-6 For This Useful Post:
  #127
Old 09-23-2025, 10:32 PM
BOB VIDAN BOB VIDAN is online now
Why am I being asked if I'm human every time I sign in?
Practicing social distancing for 65+ years
The Following 2 Users Say Thank You to BOB VIDAN For This Useful Post:
  #128
Old 09-23-2025, 11:00 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Well because that’s debatable in your case, cheers 🍻
The Following User Says Thank You to 60sstuff For This Useful Post:
  #129
tempest1964's Avatar
I think it is a way to prevent ‘bots from doing a mass attack and overloading the max performance internet server. So we can all access the forum
The Following 3 Users Say Thank You to tempest1964 For This Useful Post:
  #130
Old 09-24-2025, 04:58 AM
I see the light! Amazing how fast the 'net' changes. I just got recertified to volunteer especially around youth. What they are 'bombarded ' with!! Parents be watchful!
  #131
Old 09-24-2025, 12:19 PM
Shiny Shiny is offline
The captcha seems to be helping a lot. This is a great improvement!
Thanks again to tempest1964 for initiating this change!
There does, however, seem to be some caca slipping past this verification software. Hope it doesn't learn how to bypass the captcha well enough to flood the site again:
Name:	Screenshot 2025-09-24 101342.jpg
  #132
Old 09-24-2025, 12:32 PM
when you see something like this, hit the report button
The Following 2 Users Say Thank You to Cammer-6 For This Useful Post:
  #133
Old 09-24-2025, 06:00 PM
jhein's Avatar
jhein jhein is offline
The site is running great now. Almost as good as a well oiled Pontiac machine!
  #134
Old 09-24-2025, 06:46 PM
dataway's Avatar
dataway dataway is offline
With roller cam, or HFT ?
  #135
Old 09-24-2025, 07:06 PM
jhein's Avatar
Well, you can let your imagination make it whatever you want. Me, I'm thinking of the old site as an HFT and we just got upgraded to a roller.
The Following User Says Thank You to jhein For This Useful Post:
  #136
Old 09-24-2025, 07:29 PM
I am not a robot.
The Following 2 Users Say Thank You to Half-Inch Stud For This Useful Post:
  #137
Old 09-24-2025, 08:13 PM
jhein's Avatar
Originally Posted by Half-Inch Stud View Post
I am not a robot.
That's what all the robots say.
The Following 3 Users Say Thank You to jhein For This Useful Post:
  #138
Old 09-24-2025, 09:32 PM
72projectbird's Avatar
HFT that seems to be wiping a few lobes every now and then.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
  #139
Old 09-24-2025, 09:54 PM
unruhjonny's Avatar
Well oiled machine?
With a bad float in the carb?
… it get’s flooded every time you have to start it, making start up procedure ten times as long as it should be?
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
  #140
Old 09-24-2025, 09:59 PM
Have you had a haircut and shave lately Bob ?
The Following 2 Users Say Thank You to Baron Von Zeppelin For This Useful Post:
