Old 09-26-2025, 08:48 PM
Picketwire Bob Picketwire Bob is offline
Default HEI Clearance?
I've searched this particular forum but haven't found an answer. The question is, will an HEI distributor fit into a 67 Tempest? By that I mean more than just firewall clearance. Can a guy install and remove an HEI with the engine in its normal bolted in position? I'd like to get some feedback from others before I spend the time trying to set the HEI I've been running on my 455 that is getting installed. TIA
Old 09-26-2025, 09:33 PM
I have one in my 1967 GTO. Same car.
The Following User Says Thank You to Goatracer1 For This Useful Post:
Old 09-26-2025, 10:05 PM
It’s the first-gen Firebirds that have clearance issues because the engine is set back so close to the firewall, the HEI is not a problem with any year A-body cars.
Old 09-27-2025, 09:06 AM
Default Many Thanks !
Thanks for the input. The car right now has a 326 with points distributor and it looks tight!
I had a 69 FB that a previous owner had taken a big hammer to the firewall so the HEI would clear. I wasn't sure if he did that for the HEI on a Pontiac or the BBC they said he had stuffed in there before that.
Good to know. One more concern addressed.
Old 09-27-2025, 10:01 AM
george kujanski's Avatar
Hei in my '67 GTO 455. No issues.
George
Old 10-03-2025, 11:01 AM
ZeGermanHam's Avatar
Plenty of room to swap in an HEI on your '67 Tempest with the engine in place.
1998 BMW 328is (track rat)
Old 10-10-2025, 08:35 AM
Default Thanks, guys
Appreciate the replies on this question. The car is in the body shop so I had no was to experiment with the 326 that is sitting in it right now. Just wanted to verify fit before I invested a bunch time and money in an HEI.
Old 10-11-2025, 09:10 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
It won't fit if you plan on running a tripower.
Old 10-14-2025, 04:50 PM
oldman66gto's Avatar
oldman66gto oldman66gto is offline
Not trying to steal the thread, but have a 428 w/HEI in my '66 GTO.
Am going to hve tri-power installed when I get back to Florida.
What would be the best "standard" size HEI distributor to replace the current one?
Currently has an Edelbrock 4-bbl on a "Torker" intake, with the "HEI" distributor.
Thanks for your suggestions.
Allan Bishop
Old 10-14-2025, 06:52 PM
67Lemons 67Lemons is offline
Allan Bishop
Standard issue HEI won’t fit with tri-power, you’ll need to either use a modern small body HEI or Ready to Run distributor or a points distributor.
1972 GTO
Old 10-14-2025, 07:33 PM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is offline
Allan Bishop
Another option is the conversion system from M&H wiring. I converted my stock points distributor several years ago and have not had a problem. I also installed the voltage regulator conversion from the same dealer with no problem.
https://www.wiringharness.com/
The Following User Says Thank You to fyrffytr1 For This Useful Post:
