Old 08-10-2025, 03:41 PM
Default NOS 9796696 Trim Rings
Four NOS 15 x 7 Rally II trim rings in their original boxes. NOS and very nice but not perfect. Opened for pictures but never installed.
Long discontinued GM part and getting harder to locate.
These have the more squared off valve openings measuring 13/16” wide x 1 ¼” tall.
The rings appear to be 2 ¼” deep (may be 1/8” either way but hard to be 100 percent certain). All with the two step outer and inner edges . Overall outer measurement is 16 ¼” and inner measurement is 12 ½”. The back has 17 teeth.
Correct for your 1970 - 1972 Trans Am with optional trim rings code 471. Would also work on 1973 – 1981, 15 x 7 Rally II's but may not be correct as they used the rounded version.
Please make sure this fits your application.
Very nice condition, but I did spot a small dent and a minor blemish. More pictures can be sent if needed. $750 USD plus shipping.
Have an NOS set of four red center caps that would complement these trim rings and work on your JW or later KR rims at this link:
https://forums.maxperformanceinc.com...os+center+caps
Center caps can be sold separate of the NOS trim rings in that listing.
ID:	655423   Click image for larger version
Name:	9796696 Trim rings.jpg
ID:	655424   Click image for larger version
Name:	9796696 Trim rings rear.jpg
ID:	655425   Click image for larger version
ID:	655426   Click image for larger version
Old 10-04-2025, 03:39 PM
Available.
Would also consider trading up or down for 70 GTO NOS parts:
70-72 passenger door skin
70 only rear bumper
Rocker mouldings
Other interesting 70 GTO parts
NOS red center / centre caps also available
If you need more pictures, let me know.
Old 03-14-2026, 02:49 PM
TTT
NOS 9796696 trim rings are available.
Old 06-27-2026, 09:44 AM
Default NOS 9796696 trim rings
Available
