Myself I have some decent original chrome 1964 GTO covers on my 421 with double 1/8” rubber gaskets using Gasgacinch between them. I glued them to the covers with Permatex Hi Tack and smeared a thin layer of grease on the side the seals to the head. The reason for the double gaskets was to clear the polylocks on my Crower 1.5 rockers. No leaks so far, perhaps the additional compressabilty of the stacked rubber gaskets helps seal the covers without distorting them with excessive tightening who knows. Now you know why GM went to all cast aluminum valve covers, oil pans and valley covers and captured o-ring type gaskets on their LS series engines. They don’t leak. I took these pictures while I was replacing the driver’s side valve cover, I wanted to install the California Emissions PCV breather tube so I needed to swap to a cover with a breather hole. My builder had used Gasgacinch to adhere the double gaskets to the blanked-off cover so they easily peeled off for reuse. With only about a thousand miles on them there wasn’t any reason to toss them, I kept them in the same orientation and so far so good.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
