Look for a posi or open diff with 3.xx gears. I have a 66 gp, from what I’ve read any full size rear end will work from 65-70, and 71-76 but the pinion is splined different on the later models and that would need swapped as well.
to clarify i the housing interchange is 65-66 only as far as bolting up if referring to complete built axle , the gears and differentials interchange as you have it listed yes 65-70/71-76+yoke Pont B cars
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a 66 Star Chief Executive 59k mile 389 67 IH Scout project 2WD "Indian Scout" 69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2008 Saab 9-3 2.0T convertible |
Just a thought... You may not be aware but, low gear planetary gear sets are avail for thm 400s. there is a 2.75 low and a 3-1 low ad I think both use a 1.60 2nd gear and 3rd remains direct. Its a great way to increase acceleration of a heavy street car and have no negative effect on mileage, noise, engine wear, cooling, etc. I started using them in 1985 on one of my GTOs and loved it. Have built a few and now have one going into my 69 Bonneville Safari. In the long run, it is such a wiser choice over going with a deeper rear end gear. Hope this may help you and understand some other options.
Hundreds of Pontiacs in Az "Real Pontiacs only..no corporate nonsense!" Facebook- Pontiac Heaven Hosting- 23rd annual Pontiac Heaven weekend- Phoenix pending due to covid Pontiac Heaven Museum in process Phil 2:11 |
