72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.45 @ 88.1 mph on slippery street tires.Bad 2.19 60ft.Owned since 86' |
| The Following 2 Users Say Thank You to scott70 For This Useful Post: | ||
I also enjoy the Powell Machine videos, his general attitude and the skills he displays. His knowledge base is skewed toward the LS platform, not to say he isn't a fine machinist. His recommended cam may work as advertised, but every time I try a 110 or tighter LSA, I end up regretting it in a Pontiac street application. Not being a cam designer, I can't explain why, but the wider LSA cams with identical or similar profiles always seem to have better street manners and generally better overall results on the dyno. This is not the case with other platform engines consistently like a Pontiac. Did you happen to talk to Tim Goolsby @ Ultradyne/Bullet for a recommendation? He has over 30 years experience and seems to really know the characteristics of Pontiac V-8's. I know an engine is just an air pump and the cam doesn't know what engine it's going into. But that's really not the whole picture.
Thanks Jay, that's a good point. I just got done reading his Dyno thread and it is for sure a stout engine. I would assume with a nearly identical cam, and the rest of my setup I should probably be right where I want to be, maybe 520-530 @ 5300 ish. It's nice to bench race but even nicer to see real world results.
66 Lemans build https://forums.maxperformanceinc.com...d.php?t=876235 |
The UD HFT 239/247 @0.050 in my 455 in the 78 is on a 112. The new SR Tim ground for me(UD lobes form Bullet) for a freshen up of a 400 for the street is on a 112. And he said he usually likes 110 or tighter but was what we felt would work on this.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
I would love a custom cam by Tim but I have spent way too many attempts at trying to reach Bullet to no avail.
It's comical because for some reason every Dyno sheet I see of a Pontiac they prefer a 112-114 lsa. This completely goes against the thought that every engine is just a air pump of slightly different design and the generic cam recs like from David vizard don't apply. I'm still learning all this and this is my first performance Pontiac build. If anyone has a trick at getting tim on the line I'd be more than open to it.
When I rebuilt my engine last year I talked with Bullet about getting a cam made. At the time their lead was over 8 weeks. I went with a comp spec'd by Jeff Kauffman that uses the newer Q series lobes (QNI in my case) and I've been really impressed with the cam. The valvetrain is MUCH quieter than the comp XFI lobe cam I had in the engine previously.
Are the XFI lobes inherently noisy? I thought your valvetrain noise was attributed to the Lunati/Morel lifters, versus the new with Johnson lifters?
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
If you do some searching on the XFI lobes, it's a somewhat common complaint that it produces a noisy valvetrain. The QNI lobes on my current cam, although having more lobe lift are less aggressive on and off the ramp. Comp developed this lobe profile specifically with quiet valvetrain in mind.
| The Following User Says Thank You to JLMounce For This Useful Post: | ||
Many times Tim will suggest using a profile with less acceleration on the exhaust side for street longevity, that is another alteration that can be done. For instance that cam would probably look like 290/303 at .006” instead of 290/298, but the .050” spec is the same.
| The Following User Says Thank You to Jay S For This Useful Post: | ||
Jay's example...
Lobe HR303/3532 303 244 157 0.3532 .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
| The Following User Says Thank You to Steve C. For This Useful Post: | ||
I don't know but plenty of people have made some really good power on 455s- 461s with heads flowing less than 330cfm.
There seems to be more to it than cfm with a given ci. LS and sbc's have much lower drag and are slinging around much, mush lighter hunks of metal tha we are. Valve spring pressure can be a lot lighter too when parts do not weigh so much. Tim, keep trying. He can be hard to get ahold of but is worth the wait. |
Curious how noisy the XFI lobe cam would be with the Johnson lifters. I have KRE HR242 on the shelf, which may be XFI lobes.
Depending on the age, yes it's likely that cam has XFI lobes. You should be able to cross reference the lobe from your cam card.
With a good quality lifter, I would bet that you still hear the valves clicking as they slam shut against the seats. That cam was in my engine for about 8 years and a decent amount of miles. When Jeff went through my heads, there was no need to redo the seats. After 8 years of service the heads got Jeff's 310cfm port, new springs for the larger cam and seals. Point being the XFI lobes may have been a bit noisy, but it wasn't causing any damage anywhere.
Got my custom SR from Bullet recently in less than 2 weeks!
I'll bet that Powell saw the 3.36 rear gear along with the 2.52 low and compensated for it. Although the 230/245 spread is terribly wide and more suited for a really choked exhaust.
I like to stay at or under .600" lift on an engine that will see a lot of street miles. Maybe a little too conservative? Additional lift is pretty much free horsepower but the additional stresses start to worry me. Comments? I believe that the Butler cam is slightly warmer that the Comp and with the little extra LSA should be just as streetable. Butler would be my first choice with Comp a very close second. I think Powell might have missed the mark on this one.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
I have tried reaching out to butler again to no avail. What time of day are you guys calling Tim at to reach him?
The butler cam seems pretty interesting to me I just don't want anything too big for the street with a stick car. I feel like the 236/242 comp is a decent compromise cam and a bunch of people running them with good results. If the consensus is the butler cam on a 113 isn't too big then I like the idea of going with it.
1967 Firechicken, 499", Edl heads, 262/[email protected]" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. [email protected] mph with a 1.45 60'. Still WAY under the rollbar rule. |
While I have a favorite or two at Butler, all the techs are very good. If you keep ending up at voicemail when asking for Tim (who I haven't talked to), then I'd just say I have a cam question and asked to be connected to an available tech.
