Old 10-26-2025, 08:56 AM
Spicewood1 Spicewood1 is offline
Default 70 GTO - where did my fender crease go
Doing body prep and rough in on my 70 GTO. Original fenders and doors. I am curious about the upper fender crease - it is sharp and prominent on the fender even to the rear edge although fading a little - but it is does not continue onto the door at all. Does this crease really disappear at the door gap?
Old 10-26-2025, 10:33 AM
Shiny Shiny is online now
My 70 LeMans beater still has original paint on the door and rear fender. The body line in the rear fender ends at the gap. No sharp crease at the back of the door. The body line in the door ends about mid-way but there is a subtle but sharper curve that carries the body line along the door from front to rear. Blocking all this must be a nightmare.
Old 10-27-2025, 09:51 AM
Thanks for the reply but I'm asking about the upper fender to door crease. That is the belt line crease at the door to quarter panel. The top of the fender has a sharp line but as it hits the door where the mirror is it disappears
Old 10-27-2025, 11:35 AM
My mistake. I apologize.
My LeMans has a different fender than GTO but I believe the doors are the same and hopefully, the fender line is too.
Here's the upper left fender on mine, door has original paint:
Old 10-27-2025, 03:08 PM
Ok thanks - so the crease does actually die on the fender
The Following User Says Thank You to Spicewood1 For This Useful Post:
