Old 10-22-2024, 07:28 AM
steve25 steve25 is online now
Blowing 25k or more on a car that has once run fast times but just needs a drivetrain now and you will have learned nothing!
There no feeling of accomplishment to it.
Now if you have been there already and just want to get back into it as fast and cheaply as possible, then that’s fine.
A simple motor build making all of 450 hp should get you well into the 11s.
Old 10-22-2024, 02:54 PM
Dragncar Dragncar is offline
Built the short block strong and with light internals so it works best for you money input and with it being built strong you up the motors power level safely with better top end parts and not loose sleep at night.
1) use hard block to make a fill up to the bottom of the water pump passages.
Believe it or not even a street motor will run a minimum of 10 degrees cooler by doing this and the bottom of your cylinder bores will not get chewed up especially if you run crank strokes longer then 4.00”.
2) run longer Aluminum rods ( greater then 6.625” along with the needed pistons ) to maximize internal weight reduction.
Why is this a big deal you might ask.
The reason is that every pound of rotational weight reduction increases vehicle performance a minimum of 4 to up to 10 times more than that same amount of weight reduction done any where else on the car.
You will be stunned at how much faster the motor buzzes up and that faster rpm gain translates directly into the vehicle accelerating faster.
Dan Whittmore had a customer who he built a racing engine for that decided he just had to have aluminum rods. So, Dan rebuilt the engine, same cam, top end, compression ratio but with aluminum rods.
Ran the same ETs when done. Did rev quicker when not under a load. But down the track ran the same.
Old 10-22-2024, 03:11 PM
mrennie's Avatar
mrennie mrennie is offline
Also, havew to decide if you want it still streetable, or towing it to the track
The plan is to tow it to the track, I already have a car hauler trailer and there is zero intention to drive on the street.
Michael
1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished!
1979 Trans Am - low-buck drag car project for when I retire
The Following User Says Thank You to mrennie For This Useful Post:
Old 10-22-2024, 03:50 PM
You could do the cal-trac type of traction control on the rear for starters. It should work good for the ET's wanted plus more. If (or when) you decide you need more tire (slicks) than will fit in the wheel well, then tubs and narrowed rear with 4link or ladder bar setup.
The roller cam will help quite a bit, with a good higher stall converter. With a reasonable rear gear, it should run great in the eighth. Eighth mile will be easier on the engine/tranny also. TH400 with a good transbrake setup will make for a consistent and fast car.
Old 10-24-2024, 07:04 PM
mrennie's Avatar
[QUOTE=johnta1;6531930]If your only planning on 11's for ET, should be really easy./QUOTE]
It's not that I am planning on "only 11's", I'm more about doing a build that complements the 461 cubes with the parts I already have. If I could build a 10 second car that was reliable using stock leaf springs, no tubs, etc., then I likely would.
I was thinking (I guess naively) that many would chime in with cam suggestions that I could consider and plan my build around as a starting point.
Michael
Old 10-24-2024, 07:19 PM
mrennie's Avatar
I was looking at cal-tracs, thanks for the info.
Michael
Old 10-24-2024, 08:25 PM
prostreet64's Avatar
prostreet64 prostreet64 is offline
Someone may have already suggested this but a call to Bullit or Lunati or whatever cam manufacturer you choose would be a good starting point. Give them the parts you are working with and your goals and see what they would recommend. The intake will be a limiting factor but not too much in the modified form you mentioned. Off the top of my head I would think a cam in the 248/254 duration would be in the ball park. Maybe .550 lift. As your combo evolves you can always upgrade the cam as needed. Also, with the 461 I would go with 1&7/8" headers and 3" exhaust to cover future needs; may not make much difference with your current combo but at some point they will be needed. And as others have said don't skimp on the drive line. On my 79 with the 463 I am running a beefed up 8.5 with Strange 30 spline axles, the housing cover and True Trac differential, aluminum drive shaft and 1350 u-joints. As to traction you might want to look at the Smith Racecraft Assassin Bars. Similar setup as the Cal Tracs but more adjustable and a little easier to install. I run them with stock leaf springs and drag radials successfully. On a side note I think the rollbar rule for 1/8 mile is 7.35 or quicker.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car.
79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.60 @ 126 so far...
The Following User Says Thank You to prostreet64 For This Useful Post:
Old 10-24-2024, 08:49 PM
mrennie's Avatar
Thank you for the info. Much appreciated.
Michael
Old 10-24-2024, 09:43 PM
02Hawk's Avatar
02Hawk 02Hawk is offline
If you are planning on only tracking the car....get the car on a diet. Every 100 lbs will get you quicker.
Glass hood
Gut the interior....all the seats ( i leave the carpet in and use a race style seat. huge
cut out the door guards
drop bumpers and replace with glass
remove exhaust system
replace side glass with lexan
remove front wheel wells.
Take off stuff like wiper motors etc
convert engine to electric waterpump.
Install electric fuel pump
AND get a holly carb for your engine. Im gonna get flammed here, but at the track its way easier to jet up/down, ajust air bleeds etc between rounds
Remove front sway bar
replace brakes with light weight discs with good calipers
light weight wheels
grind off the old rust prventative
replace fuel tank with 5 gallon cell
move battery to the trunk
add a light weight starter
consider removing the alternator and charging the battery between rounds
500 lbs will get you a half second in the 1320
24 beer in a case. 24 Hours in a day. Coincidence? I think not. " Steve Wright"
The Following User Says Thank You to 02Hawk For This Useful Post:
Old 10-25-2024, 04:55 PM
You do not need a roller cam, billet caps or block fill to get what you are after.
You can do them if you want but its expensive and can be a pain. Studs and 2 bolt are fine
I would call Tim at Bullet and get a custom sft cam.
Would not mess with iron intake either, you are bracket racing.
Those Tomahawk knock off intakes work good enough and are cheap, fit you shaker too. I ran one down to 11 flat and 9-1. (but with roller cam)
Get a 850/950 Holley carb too.
Do not skimp on a converter. Lane at PTC will hook you up.
Might want to get in touch with Paul K here. Hook you up with some pistons and advice. I would get some Total Seal rings with port slots too.
Old 11-15-2025, 09:52 AM
mrennie's Avatar
Default Back at it
Back at this, and have collected all the parts to build the motor this winter.
Build will be a 400 block, 4.250" forged stroker crank, SM 72cc heads, Ross .040" dished pistons (dish still to be determined), forged I beam rods, Bullet SR cam 255*/263* @ .050 on a 110 LSA with .605" lift.
I have two 400 blocks I can use, both cast # 481988. One is a 1971 and the other is 1973. I looked them over very well before picking one to send to the machine shop, and upon visual inspection, it looked like the 1973 block would be better. I will post some pics to show the differences, then get to the sonic results.
First thing I noticed was that the 71 block did not have the "00" casting in the valley, where the 73 block did. The pic on the left is the 71 block.
Name:	71 block valley.jpg
ID:	660744   Click image for larger version
Name:	73 block valley.jpg
Michael
Old 11-15-2025, 09:57 AM
mrennie's Avatar
Looking further at the castings, they are very different in how the molds were created, and the 73 block is thicker in many areas around the mains compared to the 71.
The 71 block is on the left. Note that the area between the main and cam bores is scalloped with less material, but still appears to have reinforcement ribs where needed. Also note the slight undercut below the main cap surface. The 73 block has a lot more metal here, so I thought it would be better.
Name:	71 block webbing.jpg
ID:	660746   Click image for larger version
Name:	73 block webbing.jpg
Michael
Old 11-15-2025, 10:06 AM
mrennie's Avatar
Next thing I noticed was that the 73 block had more material under the bores where the oil galley is located. On that block, there is a bevelled area between the bottom of the bores and the lifters. On the 71 block, there is less material and you can actually see the rounded shape that was cast for the oil galley to be inside.
The other difference was how the mold went together and where the parting line is for the cylinder bores. The 73 block has the casting inline with the crank (not on the thrust side), whereas the 71 block has the casting line on the thrust side of the bores with a noticeable mark that could act as a stress riser. This made me think the 73 block would be better.
I also noted that the 71 block casting surface is much smoother than the 73 casting. Not sure if the 71 was poured in a better mold?
Name:	71 block galley.jpg
ID:	660749   Click image for larger version
Name:	73 block galley.jpg
Michael
Old 11-15-2025, 10:12 AM
mrennie's Avatar
Looking at the area where the motor mounts are located, I saw another difference.
The 71 block has a bar or lug running below the pan rail where the bolt bosses are, whereas the 73 block has an individual bump where each boss is located. This made me think the 71 was stronger in this area.
Looking at the bulkheads for the mains, the 73 is almost a straight casting and has more material from the main cap mounting surface down to the bores and cam area. the 71 block has material removed and instead of just a straight casting there appears to be strategically placed ribs. Even though the 71 block looks stronger where the mounts are, I thought the 73 would be stronger in the mains area due to more material.
Name:	71 block mount casting.jpg
ID:	660751   Click image for larger version
Name:	73 block mount casting.jpg
Michael
Old 11-15-2025, 10:27 AM
mrennie's Avatar
Default Pick a block!
Lastly, I weighed both blocks to see if there was a difference...there sure was. Using a digital bathroom scale, the 71 block weighed 192 lbs vs the 73 block that weighed 201 pounds. This was with all the same items still installed like caps, bearings, frost plugs, etc. 9 pounds is a lot!
Visually, other than the motor mount bosses, the 73 block looked stronger. More material in the main bulkheads, more material under the bores/around the oil galleys, and parting lines not on the thrust side of the cylinders.
So I sent the 73 block away for bake/blast/mag and sonic check, and got results that are not great...the right bank appears to have core shift and with the required 0.040" overbore, losing .020 per side puts the thrust sides at around .110". Cylinder #7 is also very thin on one side. Spoke with the machinist, he said he could move the bores around to keep as much material as possible, but that will require additional setup and cost.
Note that I do plan to use block fill.
Here are the sonic readings.
Name:	73 block sonic check.jpg
Michael
Old 11-15-2025, 10:32 AM
mrennie's Avatar
Default Try again
I only want to do this once, so I sent the 71 block in for the same work to see if it was better, thinking I will use whichever one is better in the bore area.
The 71 is better. Cylinder #5 & 7 have thin areas on the non-thrust side, but I can get at least .145" on all thrust sides without moving any bores around, and more if I do.
Here are the sonic results for the 71 block.
Name:	71 block sonic check.jpg
Michael
Old 11-15-2025, 10:37 AM
mrennie's Avatar
So...looking for advice to make sure I am on the right track.
While the 71 block is thinner in several areas, it has thicker bores. Should that be my primary concern? Is there any reason I should use the thicker/heavier 73 block?
If the 71 block is the way to go, is a .145" finished wall thickness on the thrust side more than enough, or should I pay extra to move a particular bore to get a certain thickness?
Appreciate your feedback.
Michael
  #38
Old 11-15-2025, 10:47 AM
Biggest question is how fast do you want to go?And then what safety equipment you will need-ie a roll bar or cage.
Keeping the Speedmaster or even brand name Edelbrock heads unported unless the car goes on a BIG diet you won;t need to worry about it.
My current 0.030 455 in my 78 Trans Am full factory interior AC box still on but no condenser up front with light ProStar wheels and 9" radial no tube slicks weighed 3750lbwith my 150 lb butt in it. Good air-a rarity here ran 10.90s @124mph. Ported E heads Ultradyne hydraulic flat tappet 239/247 @0.050 and 1.65 HS rocker on exhaust 1.8 Crowers on intakes. Ported Torker II and a Holley 4781 850 DP jetted on e click lean form factory. 2" Hooker Super Comp 4202 headers into 3" X and ultraflows 3" tailpipes. 4.10s and a 10" Continental convertor.
Previous 455 similar but a roller cam and aluminum rods ran about the same but had a 5000 stall and 4.56s. Similar times but a faster 1.5 60ft and 6.9 @ 100 1/8. STOCK 10 bolt 28 spline axles Eaton posi . Just freshened rear last year and dropped back to 3.42s for street upgrading to 30 spline Eaton and axles but factory axles looked fine no twist. LOTS of 1/4 mile passes on the rear. I does has 79-81 rear discs so kind of c clip eliminators. years ago I asked Tom at Tom's differenitals about new axles said if you are using the stock posi it will break before the stock axles. The Eaton was stronger.
Rear springs were the trick to hooking up over traction bars . Tri City "Launcher" springs that lots of NHRA Stockers used before caltracs came out. Built like the old Mopar Super stock springs with second and third leaves going further up second under spring eye. Now Caltracs and their split springs are the best what I have ion the IA/Camaor.
To slow it down with no roll bar I added back the heavier 8" Snowflakes with 235 60 -15 fronts and heavier DOT 275-60-15 M/T rear tires and put the spare back in it. Ran 11.50s @117 in Texas heat all day long WITH an air filter in the Shaker.
I would add C clip eliminator and good axles and a decent Eaton posi or trutrac and go 30 spline. Most the bearing and axles are identical to 30 spline 12 bolts other than the C clip button is thinner.Strange has or had a C clip eliminator that uses the taper Ford 3.150 bearing that is better at side loads if you are on the street any. You won't break the 10 bolt! Most leaf spring cars are not going to spin the axle tubes as easily as a coil spring car. If you have the tubes welded be sure they use a jig to keep them straight. I have seen 9 second F bodies using a 10 bolt rear.
First motor with the roller cam I ran a ported Pontiac HO intake and a Carb Shop worked over 73 SD Q jet. Swapping at the track with an adapter and 850 demon DP picked up 0.3 seconds! Swapping on the Torker II picked up even more but not done at the track. Holley?Demons much easier to tune at the track than pulling the top off a Qjet-otherwise on a Q jet you are just changing secondary rods. And using a wiode band th BS about primary jets/rods don;t do much on a Qjet is just wrong they do!
Forgot just a 2 bolt main 455 block.
  #39
Old 11-15-2025, 11:38 AM
tom s tom s is offline
3X B man!Tom
  #40
Old 11-15-2025, 03:54 PM
mrennie's Avatar
I am far past the point of considering the purchase of an existing race car. I'm building my own and have collected all the parts over the past year so let's focus on helping me achieve that. Tragically, my wife passed away unexpectedly in July and my car hobby and two Labrador retrievers are pretty much what is getting me through this, so....
....I would like to focus on my recent posts about which block is best to use for this build.
Thank you
Michael
