Old 11-17-2025, 10:51 PM
Shiny Shiny is online now
Default How To Reflectors?
How have you refinished tail light reflectors?
Is a "chrome" spray paint good enough or does it need the gloss base/chrome thing? How well does either hold up?
Old 11-18-2025, 02:41 AM
dataway's Avatar
dataway dataway is offline
I ended up just using the closest to chrome look spray can I could find (which I don't remember). None of them have seen enough exposure to comment on longevity.
I basically just got tired of looking for the perfect solution
Old 11-18-2025, 03:43 AM
From a decade old post:
Testing an idea I read about; left side tail light has white painted reflector, other side stock silver - not much difference I can see
Old 11-18-2025, 01:46 PM
mrennie's Avatar
mrennie mrennie is offline
I did the same, came out great.
Michael
1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished!
1979 Trans Am - low-buck drag car project for when I retire
Old 11-18-2025, 06:07 PM
misterp266's Avatar
I’m with Scarebird. I use rustoleum flat white. (metal housings)
" Darksiders Rule "
Old 11-18-2025, 06:15 PM
VCho455's Avatar
VCho455 VCho455 is offline
If you're looking to maximize light output you can use HVAC duct sealing tape. The aluminum backed style linked. For maximum output retrofit mirrored reflectors out of late model taillights. I did this on my Suburban and pretty much doubled the light output of my backup lights1
https://www.oneida-air.com/ductwork/...3f2olXZSV3iOIc
ID:	660992   Click image for larger version
Old 11-18-2025, 07:46 PM
Thanks to all for sharing their experience.
I conclude the difference between white/silver/"chrome" paints and a "true" metallic reflecting surface may be real but all are likely "good enough" for me.
....something about engineers creating problems when none exist?? APS (analysis paralysis syndrome) ???
The bigger challenge may actually be prepping the insides to give any coating a chance to adhere.
Mike
Old 11-18-2025, 08:38 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
I wonder if anyone has tried to vinyl wrap it in chrome?
So long, farewell.
Old 11-18-2025, 11:14 PM
mrennie's Avatar
I washed mine really well with soap and water and a fine scotchbrite to remove anything loose and create some tooth, then wiped with water based wax and grease remover prior to masking and painting.
Michael
The Following User Says Thank You to mrennie For This Useful Post:
Old 11-18-2025, 11:57 PM
242177P's Avatar
242177P 242177P is offline
I wouldn't expect vinyl to do so good on account
of heat. And I expect it'll kinda act as an insulator,
further exasperating things.
Old 11-24-2025, 02:42 PM
Storm1's Avatar
Storm1 Storm1 is offline
I'll eventually end up doing the same thing I did with my Buick
1. Remove
2. Media blast
3. Used off the shelf chrome spray.
'79 Pontiac TA 400
350 Coan trans
Hurst Dual Gate manual valve body
Holley Sniper EFI
Heritage Brown
Old 11-26-2025, 11:54 AM
Storm1's Avatar
This is what i did for my Buick and they turned out good enough.
Removed tail lights
(lightly) media blasted
Painted with rattle can chrome off the shelf
'79 Pontiac TA 400
350 Coan trans
Holley Sniper EFI
Heritage Brown
Old 01-15-2026, 07:24 PM
I tried using the Spaz Stix system that worked well on my dash bezel.
It wasn't a total disaster, but I could choose to call it that.
The idea is to get a gloss black undercoat, then spray the thin metallic layer on top.
The gloss black fought back. I first scotchbrited it all, then wiped it down with wax remover. The Spaz Stix gloss black would not wet out evenly. So I removed it all with lacquer thinner and tried again with a Rustoleum gloss black.
Same behavior. For some reason, neither enamel wanted to wet. It looked rough... maybe something to do with the residual aluminum being spotty? I got a few runs from trying too hard to get it to level.
I didn't try again, left the runs, and just did the chrome spray on top of the not so perfect black.
Not my best work. Not anyone's best work. But it will probably reflect just fine.
White or chrome paint would have been easier, even if it didn't wet out any better. Maybe a plastic adhesion promoter or epoxy primer would have been worth the effort?
Mike
