#261
"Those poor souls have made the fatal mistake of surrounding us. Now we can fire in any direction" 1970 Trans Am RAIII 4 speed 1971 Trans Am 5.3 LM7 1977 Trans Am W72 Y82 1987 Grand National |
#262
I really think the 70k buyer had extreme high hopes of an ice blasting miracle.
Definitely appeared to me it had been attempted. The underside seemed to have a different appearance than Round 1. WOB's website offers ice blasting service. I figure the owner lost around 20k all-in. And was lucky it got 59 after a 52 Maybe new owner will keep it and make some improvements. And Ransom owes me a beer for taking the under , on the O/U . :grin: |
| The Following User Says Thank You to Baron Von Zeppelin For This Useful Post: | ||
#263
I neer saw the curve ball coming. I was just commenting on the bidding was more believable this time when he posts the reserve was off. Should have only gone to 48-50K. I believe it is a 40-5K car. Had it been a 4 speed, the bidding would have been good. I'm good with owing you a beer...
So long, farewell. |
#264
#265
Want!
Esquire '74 T/A 455 Y-code SD clone previously on Dawson's Creek: '74 T/A 400 '81 AMC SX/4 '69 FB 350 |
#266
And trying to rehash the 18k miles - original paint mythology .
The underside photos blow the lid off the mileage. That's not Norwood primer and not a speck of Red overspray underneath. The previous intentional incorrect gauge setting on paint readings negate factory paint. Nice car that shouldn't be getting that type of carnival miscreant representation. |
| The Following 3 Users Say Thank You to Baron Von Zeppelin For This Useful Post: | ||
#267
Yeah once I looked at underneath again yesterday and saw the rear floor plugs painted that oxide primer color I was like no way. And where did the original steering wheel go while we are at it. Ha
| The Following User Says Thank You to 65madgoat For This Useful Post: | ||
#268
I can at least tell you the valve cover decal isn't orginal.
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '74 Ventura 350 '69 AMC Javelin SST |
| The Following 3 Users Say Thank You to Verdoro 68 For This Useful Post: | ||
#269
One of the rear floor pans has had repairs , yet it's all the same finish.
The previous seller didn't post well lit underbelly pictures like there are now on the outdoor lift. It's a real nice restored car with 118,000 miles 150k wouldn't be out of line. Other than the tire switch - it does present a little better this time |
#270
Let's see how far this one gets... And, I wonder how early this one is for a 4 speed?
https://bringatrailer.com/listing/19...d-trans-am-14/
#271
This is at least a mid-year TA (03C). Low options for a manual though.
n110xxx is earliest I have, N172xxx the latest.
#272
I can't unsee those valve cover decals now.
| The Following User Says Thank You to Verdoro 68 For This Useful Post: | ||
#273
This auction ends tomorrow. Another one trying to say low mileage when you can see the odometer numbers don't line up in the front. And, what's with the number 5 in the 395816 on trim tag (almost all will have a 0 in that position and a high number for the build to go out on that day)? 03C (15th-21st) and a ship date of 3-15 (Friday), mighty tight. Carburetor is an early one because they held off on 4 speeds until the Borg-Warner transmissions came out (i don't do BaT anymore to comment).
| The Following User Says Thank You to Held for Ransom For This Useful Post: | ||
#274
You're right Mike, that N110xxx is not 4sp. (probably thinking earliest SDTA I have)
Earliest 4sp would be N139xxx. (which could be this one)
| The Following User Says Thank You to johnta1 For This Useful Post: | ||
#275
#276
Current Pontiacs -1973 Formula SD455 - #'s auto orig paint 1972 Trans Am - 4 speed orig paint 1966 2+2 convertible - 421 4bbl automatic 1967 Grand Prix - 4 speed orig paint 1967 GTO - 4 speed orig paint 35k orig miles Last edited by 71GP76TA; 01-09-2026 at 12:28 PM. |
#277
Baron, see if you can get the dates off the Honeycomb rims ( https://forums.maxperformanceinc.com...d.php?t=883569 ). His car was assembled a day before my Formula ( forums.maxperformanceinc.com/forums/showthread.php?t=873846 ). Approx. 220 VIN units, but almost 10,000 body units earlier. His front license plate holder is also a '70-2 unit, not '73.
Dennis' SD was probably built the day after this one too.
So long, farewell. Last edited by Held for Ransom; 01-09-2026 at 07:22 PM. |
#278
And Baron, don't forget about the million dollar starter pics.
#279
Window sticker indicates spare should be full size Honeycomb. Space Saver and label were added. Also, emissions decal is incorrect for SD engine. Can't really get a handle on Formula steering wheel being correct. Master cylinder was replaced. A whole lot of little things are quickly adding up to lose money in the end.
#280
I'm still not convinced it wasn't in an accident. Can he show the stamping from the fenders? More driver side than passenger side (area circled in red)...
Hopefully he kept the replaced alternator.
