Old 09-17-2025, 04:13 PM
72projectbird's Avatar
After the reserve was knocked off - I think the final bids just went the extra mile to get it and be done.
It did seem like it was going to stall out in the 40's
Amazing what Brewster Green does to a car these days
50-55 seemed like plenty , but they wanted it enough to open another bottle..
I really wanted it to fall flat just to see the selling dealer blow a gasket. At the same time, I believe it was a commission car, so I'm happy for the actual seller.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
  #262
Old 09-17-2025, 05:30 PM
I really think the 70k buyer had extreme high hopes of an ice blasting miracle.
Definitely appeared to me it had been attempted.
The underside seemed to have a different appearance than Round 1.
WOB's website offers ice blasting service.
I figure the owner lost around 20k all-in.
And was lucky it got 59 after a 52
Maybe new owner will keep it and make some improvements.
And Ransom owes me a beer for taking the under , on the O/U . :grin:
  #263
Old 09-17-2025, 07:45 PM
Held for Ransom's Avatar
I neer saw the curve ball coming. I was just commenting on the bidding was more believable this time when he posts the reserve was off. Should have only gone to 48-50K. I believe it is a 40-5K car. Had it been a 4 speed, the bidding would have been good.
I'm good with owing you a beer...
So long, farewell.
  #264
Old 12-06-2025, 10:21 PM
Another back to sell again.
https://bringatrailer.com/listing/19...d-trans-am-15/
So long, farewell.
  #265
Old 12-07-2025, 12:07 AM
Want!
Old 12-07-2025, 03:11 AM
And trying to rehash the 18k miles - original paint mythology .
The underside photos blow the lid off the mileage.
That's not Norwood primer and not a speck of Red overspray underneath.
The previous intentional incorrect gauge setting on paint readings negate factory paint.
Nice car that shouldn't be getting that type of carnival miscreant representation.
The Following 3 Users Say Thank You to Baron Von Zeppelin For This Useful Post:
  #267
Old 12-07-2025, 01:44 PM
65madgoat's Avatar
Yeah once I looked at underneath again yesterday and saw the rear floor plugs painted that oxide primer color I was like no way. And where did the original steering wheel go while we are at it. Ha
The Following User Says Thank You to 65madgoat For This Useful Post:
  #268
Old 12-07-2025, 03:37 PM
Verdoro 68's Avatar
I can at least tell you the valve cover decal isn't orginal.
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 3 Users Say Thank You to Verdoro 68 For This Useful Post:
  #269
Old 12-07-2025, 04:02 PM
One of the rear floor pans has had repairs , yet it's all the same finish.
The previous seller didn't post well lit underbelly pictures like there are now on the outdoor lift.
It's a real nice restored car with 118,000 miles
150k wouldn't be out of line.
Other than the tire switch - it does present a little better this time
  #270
Old 12-08-2025, 06:33 PM
Let's see how far this one gets... And, I wonder how early this one is for a 4 speed?
https://bringatrailer.com/listing/19...d-trans-am-14/
So long, farewell.
  #271
Old 12-08-2025, 07:20 PM
This is at least a mid-year TA (03C). Low options for a manual though.
n110xxx is earliest I have, N172xxx the latest.
  #272
Old 12-08-2025, 07:40 PM
Verdoro 68's Avatar
I can't unsee those valve cover decals now.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #273
Old 12-14-2025, 11:54 AM
John, do you have proof that the X-N110xxx came from the factory with a 4 speed?
This auction ends tomorrow. Another one trying to say low mileage when you can see the odometer numbers don't line up in the front. And, what's with the number 5 in the 395816 on trim tag (almost all will have a 0 in that position and a high number for the build to go out on that day)? 03C (15th-21st) and a ship date of 3-15 (Friday), mighty tight. Carburetor is an early one because they held off on 4 speeds until the Borg-Warner transmissions came out (i don't do BaT anymore to comment).
So long, farewell.
  #274
Old 12-14-2025, 03:03 PM
You're right Mike, that N110xxx is not 4sp. (probably thinking earliest SDTA I have)
Earliest 4sp would be N139xxx. (which could be this one)
  #275
Old 01-09-2026, 12:03 PM
Default This week on BAT...73 formy
https://bringatrailer.com/listing/19...omments-anchor
Old 01-09-2026, 12:20 PM
Haven't seen that one before. Interesting to see what it goes for.
  #277
Old 01-09-2026, 06:53 PM
Baron, see if you can get the dates off the Honeycomb rims ( https://forums.maxperformanceinc.com...d.php?t=883569 ). His car was assembled a day before my Formula ( forums.maxperformanceinc.com/forums/showthread.php?t=873846 ). Approx. 220 VIN units, but almost 10,000 body units earlier. His front license plate holder is also a '70-2 unit, not '73.
Dennis' SD was probably built the day after this one too.
So long, farewell.
  #278
Old 01-09-2026, 09:09 PM
And Baron, don't forget about the million dollar starter pics.
So long, farewell.
  #279
Old 01-10-2026, 11:26 AM
Window sticker indicates spare should be full size Honeycomb. Space Saver and label were added. Also, emissions decal is incorrect for SD engine. Can't really get a handle on Formula steering wheel being correct. Master cylinder was replaced. A whole lot of little things are quickly adding up to lose money in the end.
So long, farewell.
  #280
Old 01-11-2026, 11:16 AM
I'm still not convinced it wasn't in an accident. Can he show the stamping from the fenders? More driver side than passenger side (area circled in red)...
Hopefully he kept the replaced alternator.
ID:	663484   Click image for larger version
So long, farewell.
