Old 12-17-2025, 01:55 PM
punkin punkin is offline
Default -AN radiator fittings
Hello all,
Moving over to another project I've got started up. Working on a 69 Firebird and will be ordering a custom radiator. Curious if anyone has converted to -AN fittings and if so, what sizes are you using top and bottom. I've got to think the factory had something in mind when they made the two ports different sizes.
I should mention;
I am planning to use a Merziere electric water pump (I've had very good rusults with them in the past) not sure if I will use a variable speed control of any kind yet or not.
I will be using PWM brushless fans with controller and an inline temp sensor at the radiator bottom hose connection.
1968 Firebird
IA2 522
340 E-heads
Northwind 950 Carb
4L80E
3.50:1 Rear
1969 Firebird
IA2 535
Northwind (Induction undetermined)
3.50:1 Rear
Old 12-18-2025, 01:18 PM
Squidward's Avatar
Look up "Fast Monty's Garage" on YouTube. He has a 69 GTO. He just recently did a video about AN radiator fittings.
It's not so much my thing, even tho I LOVE the functionality of AN fittings for fuel lines, and I HATE twisting off stuck hoses and clamps.
https://youtu.be/ywt1HtPKtJ4?si=En8bs1gfFYdZsXqi
He also did a number of videos about fan cfm comparisons. Because of his videos, I bought a brushless fan for the slow startup current instead of the huge starting spike for a conventional fan
The Following User Says Thank You to Squidward For This Useful Post:
Old 12-18-2025, 08:35 PM
Thanks very much!
I've got brushless fans on another project I've been working on. I too like that soft startup.
1968 Firebird
IA2 522
340 E-heads
Northwind 950 Carb
4L80E
3.50:1 Rear
1969 Firebird
IA2 535
3.50:1 Rear
