Old 12-19-2025, 08:11 PM
JOHNNYGOAT's Avatar
JOHNNYGOAT JOHNNYGOAT is offline
Default Fender I.d.
I bought these fenders for my 70 formula. They were sold to me as 70-73 stock fenders. Can someone tell me what year they are from by looking at these pictures. I'm wondering why one is wider then the other in this area.
ID:	662419   Click image for larger version
71 GTO Convertible 455HO AT Canyon Copper
Old 12-19-2025, 09:55 PM
Mr. G Mr. G is offline
Not by looking at those pictures. If you could lay them out where we can actually see what they look like then maybe. I do know that there are dates on the firebird fenders located on the upper inside edge along where the side of the hood would be when closed. That is how to tell exactly what year they are.
Old 12-20-2025, 02:25 PM
JOHNNYGOAT's Avatar
Here's some more pictures but the area I'm talking about I circle. Why does this area look wider and holes seem to be in a different area.
ID:	662457   Click image for larger version
ID:	662458   Click image for larger version
ID:	662459   Click image for larger version
ID:	662460   Click image for larger version
Old 12-20-2025, 02:28 PM
JOHNNYGOAT's Avatar
More pictures
ID:	662462   Click image for larger version
ID:	662463   Click image for larger version
ID:	662464   Click image for larger version
Old 12-20-2025, 02:57 PM
JOHNNYGOAT's Avatar
And what would these holes be for they are only on the one fender.
Old 12-20-2025, 03:03 PM
Stan65 Stan65 is offline
Johnnygoat,
If the front area you asked about is a different shape fender to fender, it is bent. In the picture below the circled area in yellow, the fender brace is raised. This was a 1973 change so your fenders if they both have this raised area are off of a 73. They will fit 70 to 73 but only correct for 73.
This is if the front valance brackets are original to the fenders. If they’ve been added on then hard to tell what year originally they were.
The Following User Says Thank You to Stan65 For This Useful Post:
Old 12-20-2025, 03:09 PM
I think they are probably 73 possibly 74 fenders?
Still need better pics of the fender top. Is the mounting area for hood hinges have threaded holes or just a hole?
Were they supposed to be original or aftermarket?
Old 12-20-2025, 05:26 PM
Held for Ransom's Avatar
Look for stampings and report findings...
ID:	662476   Click image for larger version
So long, farewell.
Old 12-20-2025, 06:22 PM
JOHNNYGOAT's Avatar
Both fenders have a hump where the braces would go
Hood hinge holes are just square holes. New pictures seem to say one is a 72 and a 73 if I am correct. Still can't figure out what those other 2 holes are for on the 72
ID:	662478   Click image for larger version
ID:	662479   Click image for larger version
Old 12-20-2025, 08:34 PM
I'm not seeing the square holes for either hood hinge side. Holes in the side of the PS fender are not used for anything I know of. And with the strike late in '72 model year build, it may have been used on a '73. Other is a late for '73 (July 23 '73) and may have been used on an early '74.
So long, farewell.
Old 12-20-2025, 11:02 PM
Norwood's Avatar
Norwood Norwood is offline
The humps for the supports to the core support and the valance brackets point to 73 fenders. The hood hinge nuts say factory installed not parts dept replacements. I don’t believe anyone has been able to ID what those two holes are for. IMHO
The Following User Says Thank You to Norwood For This Useful Post:
Old 12-21-2025, 11:15 AM
JOHNNYGOAT's Avatar
Sorry guys square holes are mounting spots. And as Norwood says hood hinge holes are nuts on back side. If they are both 73 fenders why is the end profile where bumper attaches different see first and second post.
Old 12-21-2025, 05:14 PM
I know I must type in circles, but I think I stated the '73 dated one was a little late and was probably used on a '74. Picture of a '74 brace.
So long, farewell.
Old 12-21-2025, 07:31 PM
Just looked at my '73 Formula which also has a '72 dated fender on the passenger side and a '73 dated fender on driver's side. The two holes in the passenger side fender are for an A/C component and there are also two holes in the inner fender just below the ones in the fender which are associated with the same A/C component. Looks to be a canister of some sort but not sure exactly what it is but someone on here with an A/C car probably can enlighten us,
Old 12-21-2025, 07:56 PM
JOHNNYGOAT's Avatar
Sorry Ransom that makes sense one is a 73 and other a 74. Thanks
Old 12-21-2025, 08:53 PM
I believe the muffler bolts to the inner fenderwell, not the fender.
So long, farewell.
Old 12-23-2025, 12:39 PM
unruhjonny's Avatar
it would be great if someone here had the ability to post each different (front lip) fender configuration.
IIRC starting for MY-1974, the holes on the upper/forward edge changed for attaching to that years' front end;
The 70-73 front bumper didn'tt directly attach to the tops of the fenders, but the 1974+ ones did.
The bracket for the lower valance was just a part of the equation - but I don't believe that the lower valance bracket is sufficient to ID by it's self... especially since they can be swapped.
I believe it goes something like this:
first type: 1970-1973
second type: 1974-1975
third: 1976 (one year?; I believe the header panel attached the same, but the lower bumper cover also bolted along the fender lip, which was new for that year)
fourth: 1977-1978 (maybe it used the same configuration as 1976??)
fifth: 1979-1981 (but maybe the same as 1977/1978)
1970 Formula 400
