Old 12-24-2025, 04:31 PM
pvp44 pvp44 is offline
Massachusetts, my bad. I guess if I were to sell the car it would be right to reduce the price $200.00 in todays dollars to reflect how it was ordered, HA HA!
The Following User Says Thank You to pvp44 For This Useful Post:
  #122
Old 12-24-2025, 05:45 PM
As far as Carousel 69 Ram3 Judges , the Pattern Cars top the heap in desirability .
Sometimes can equal higher value.
Current condition and originality dictate most of the value.
The Pattern Cars had such great options it's hard to beat them.
$200 discount sounds like fair play.
In my case , I'm not a hood tach fan and would rather have non-pattern with in-dash tach.
Some people demand hideaways , or AC , etc...
I wouldn't alter a pattern car , but I would most any others.
  #123
Old 12-24-2025, 06:07 PM
Color-Blocks were definitely done at Fisher Body for painting.
No idea after that.
So few Patterns had AC they probably didn't need to scatter them much , other than to separate any coincidental AC cars from going back to back.
  #124
Old 01-25-2026, 06:28 PM
I just added another Pattern Judge!
Zone 07 #00063
Pattern Judges with Comments
  #125
Old 02-13-2026, 07:02 PM
Thanks to Angelo for giving me correction to Zone 04 #00045
The Zone office # is 995.
  #126
Old 03-06-2026, 09:10 PM
Bad Judgement Bad Judgement is offline
I am the current owner of 02 -00119 and it is on your list so I assume you already have the PHS info from my car?
The Following User Says Thank You to Bad Judgement For This Useful Post:
  #127
Old 03-06-2026, 09:54 PM
Yes.
(from North I believe)
  #128
Old 03-11-2026, 02:13 PM
Mcronk Mcronk is offline
I have been out of the "loop" for a while. Not sure if you have the data on my car 00047. It is a pattern Judge 01D with A/C , automatic and Parchment interior built at the Atlanta plant. Sold at Jack Smith Pontiac in Huntsville Alabama. Sorry for the low quality of the PHS copy.
  #129
Old 03-11-2026, 08:10 PM
Yes, it is in there.
Link to the webpage is 4 or 5 posts from this one.
  #130
Old 03-12-2026, 08:13 AM
All that’s left from what I assume is a pattern judge. Belongs to someone local to me, removed long ago. Car was in rough shape and it is unknown what happened to it.
Sold new at Royal Pontiac (Dealer# 07-679)
70 Formula 400/auto
  #131
Old 03-12-2026, 08:47 AM
Do you know the VIN for it?
  #132
Old 03-12-2026, 12:05 PM
No, sorry, I wish I did
70 Formula 400/auto
The Following User Says Thank You to Singleton For This Useful Post:
  #133
Old 04-10-2026, 03:06 PM
Interesting, that trim tag is by far the lowest body number of any of the Judges in my listing (556355). It is a 01D but all the ones I have that are 1B or 1C have much higher body numbers. Perhaps they had produced a bunch of Judge (TT with trunk wing holes punched) bodies ahead of time and built them out in substantially different order?
Old 04-11-2026, 02:58 PM
Here's a page I made for the Baltimore cars/cowltags that I have.
These are not just Judges but all Baltimore that I have,
Interesting data I think.
Baltimore built cowl tag data
Also added the PHS shipped date if I have that data.
  #135
Old 04-14-2026, 09:04 AM
Updated data on Balt. tags. (from NORTH mostly)
69 Baltimore Tag Data
John, can you check the tag for 172765? I think it may have been misread?
I have checked a lot of my 69 Bird tags and found some I misread after seeing 'wrong' sequences.
Also the vin 170503 I think the period after the BAL should have been a '5' which aligns with the other data?
I have found when doing the 69 Firebird tags that the BDY # seems to be in sequence as they were sent to the Bird factories, this came from camaros.org (Kevin Sonen maybe?). It explained a lot of weird sequences between LOS/VN, U and NOR.
I would have to look and see if some other A-body plant used that?
If you sort by the BDY tab at top of table it will show when the BDY order was sent to factory. The VIN may not be sequenced with BDY, which would depend on when it went to the line. The 'UNK' # will kind of say when it went to the line, while the Date code will follow if no extra detours (work on it) was needed.
We need to find someone who was in the 'upper' management on how this work flow worked.
Look at camaros.org on the tag section for some insight.
  #136
Old 04-14-2026, 11:52 AM
Added my tag data to it now.
  #137
Old 04-14-2026, 04:00 PM
I double checked 172765, the info I provided is correct. tag looks legit, photo is clear and car was a low value car in poor condition, not likely fudging going on. probably a typo at the factory
As for 170503 (a judge ragtop btw), the tag also looks legit, there is a comma where you should have the 5. probably also a factory typo.
Some other plants used Body numbers that were specific to each body style and model. I suspect that the UNK# number at Baltimore might be some kind of order number that Fisher body received from the car division. I'd love to see trimtags for other car makes produced at Baltimore the same model year.
  #138
Old 04-28-2026, 01:44 PM
I added another Pattern Judge in the web page I made.
Zone 24 #00017
  #139
Old 05-31-2026, 10:51 PM
OneJudge OneJudge is offline
Default Thus could solve many unanswered questions
Especially the mystery you have known going back to 2015 https://forums.maxperformanceinc.com...1&d=1780282168
  #140
Old 06-02-2026, 10:58 AM
hmmm
