Old 01-12-2026, 06:18 PM
Vol's Avatar
Vol Vol is offline
Default 1968 Pontiac LeMans/GTO clone convertible
Project got stalled.
Sandblasted and powder coated frame. New body bushings
Hotchkis TVS Stage 2 Suspension System front and rear.
Baer Disc brakes all around.
New steering box.
10 Bolt rear 3.42 gears
Inline tube stainless steel brake and fuel lines
Pontiac 455 +.60 over. Crower cam, standard crank, 6x-8 heads. 72 cast iron intake, Cliff Ruggles Quadra-jet, DUI HEI distributor, Ceramic coated headers, 4 core Harrison radiator, factory fan and shroud. Engine broken in. Pontiac turbo 400 short shaft with shift kit. New Continental torque converter.
Nitto tires 275/40/18 rear, 245/40/18 front on Boss Motorsports 338 gun metal wheels.
Rotisserie restoration on the body. New front floor pans. New top cowl/windsheild panel. New passenger rocker. Section of drivers side rocker. Lower cowl on both sides repaired. Both outer rear wheel tubs and quarter panels replaced. Patch panel under the rear seat. Converted from bench seat to bucket seat brackets. Dash radio panel replaced. Bottoms of fender repaired. Door corners repaired.
Truck lid and GTO hood are stock and very nice.
Body and all panels were blasted, metal prepped, epoxy sealed, seam sealed. Underside of body was finished in Upol bed liner color matched to meridian turquoise. Inside tub has been base coat clear coat painted in meridian turquoise.
Body is on frame. Full rolling chassis, with engine and transmission drive shaft. Trunk, rear bumper, doors, hood, fenders and front valence all fitted and gapped on car. The endura front is next to get fitted. Really close to start body work.
Parts I have for it:
Two heater core boxes in epoxy primer. Good heater core.
Hide-away setup or fixed front end. All the pieces.
Hood scoops
Wiper motor
Dash and gauges
Steering column for an auto on the floor
Bucket seats
Center counsel with His/Hers shifter
Rear seats
Convertible frame (top is on it but will need to be replaced)
Rear bumper has been straightened, just needs to be chromed. Rear tail lights and buckets.
Widow glass and all the mechanisms
Dash pad
Glove box door.
All under dash parts
Wing widows
Windshield moldings
Convertible top moldings
New master cylinder and lines
Emergency brake
Brake pedal
Gas pedal
Parts needed:
Full interior. Seats need to be redone.
Convertible top.
Gas tank and sending unit.
Complete wiring harness
Exhaust headers back
Door handles, lock set
Wheel opening moldings
Rocker moldings
Badges
I have various smaller parts and interior pieces. Most items to complete the car.
$30K
ID:	663534   Click image for larger version
ID:	663535   Click image for larger version
ID:	663536   Click image for larger version
ID:	663537   Click image for larger version
Old 01-12-2026, 06:20 PM
Vol's Avatar
Vol Vol is offline
Default More photos
Photos
ID:	663539   Click image for larger version
ID:	663540   Click image for larger version
ID:	663541   Click image for larger version
ID:	663542   Click image for larger version
Old 01-12-2026, 06:23 PM
Vol's Avatar
Vol Vol is offline
Photo 1
ID:	663549   Click image for larger version
ID:	663550   Click image for larger version
ID:	663551   Click image for larger version
ID:	663552   Click image for larger version
Old 01-12-2026, 06:24 PM
Vol's Avatar
Vol Vol is offline
Photo 2
ID:	663554   Click image for larger version
ID:	663555   Click image for larger version
Old 05-03-2026, 12:19 PM
Vol's Avatar
Vol Vol is offline
Bump in price $22,500
Old 06-02-2026, 05:28 PM
Vol's Avatar
Vol Vol is offline
$20K
