Old 01-15-2026, 01:30 PM
78w72 78w72 is offline
Originally Posted by peters23 View Post
Make sure you check for clearance between the valve retainer and the oil seal at full open lift. The oil seal bosses often need to be cut down lower to add clearance.
Why would changing the stock studs to 7/16 studs require checking or cutting down bosses to add clearance?
