Old 01-21-2026, 05:35 PM
If you decide to go GM original note that any power window setup from any GM 70 to 72 A body two door hardtop or convertible is the same and will work in your 72 convertible. You need the four regulators with the motors on them, the wiring harnesses with the rubber baffles that go through the door jams, the relay that bolts in near the driver kick panel and a circuit breaker to replace the fusing bar in your fusebox now. You will also need two sizes of hole saws for the front of the doors and the jam on the side of the cowl.
