Old 01-22-2026, 08:52 PM
AG's Avatar
AG AG is offline
Default GTO factory auto shifter
Did the auto shifter with the TH400 in the GTO work like the Dual Gate from 1968?
Old 01-23-2026, 09:51 AM
Kenth's Avatar
Kenth Kenth is offline
Yep, pull the lever down to L, push the lever towards the passenger side and shift forward one step at a time.
From The 1970 Performance Brochure:
Name:	70 GTO Rally Sports Shifter.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
The Following 2 Users Say Thank You to Kenth For This Useful Post:
Old 01-23-2026, 03:22 PM
AG's Avatar
AG AG is offline
Thanks so much!
Old 01-23-2026, 04:52 PM
65 Lamnas's Avatar
The 69-later A and G body shifters worked similarly to the 67-68 Dual Gate GTO shifters.
They had just a standard-looking single gate, but functioned similarly as the shift shaft pivoted to the right side of the gate. I think they were referred to as a "Rally shifter" and were on those cars thru 1972. Not sure after that. Also not sure if the F-body cars had them or not, but I "think so".
Old 01-23-2026, 08:45 PM
AG's Avatar
AG AG is offline
Did all GTOs and GPs from '69-'72 get this shifter?
Old 01-23-2026, 08:59 PM
65 Lamnas's Avatar
Is this thing on?
Old 01-24-2026, 03:16 PM
AG's Avatar
AG AG is offline
Alrighty then.
Old 01-24-2026, 11:38 PM
scott70's Avatar
scott70 scott70 is offline
I had a auto 79 TA once and the shifter worked the same way but it was a little awkward. Not as smooth as like a B&M quicksilver or a ratchet shifter like that when your slapping through the gears.
