Old 02-06-2023, 11:46 AM
mklinger's Avatar
mklinger mklinger is offline
That filter has a diaphram in it, basically a one way valve. Under vacuum or zero pressure it remains closed. If crankcase pressure would exceed atmospheric it opens.
I suspect I would not have this issue with the 10's running to the air cleaner on my N/A motor but in other configurations, such as a boosted setup, if crankcase pressure built up and pressurized the the crankcase that breather would vent the pressure.
There are no problems..only solutions.
  #42
Old 02-07-2023, 02:46 AM
wakesupremo wakesupremo is offline
Thank you. Makes perfect sense now.
  #43
Old 04-09-2023, 05:46 PM
mklinger's Avatar
Have a look at this thread and the route I went.
https://forums.maxperformanceinc.com...d.php?t=864137
  #44
Old 02-23-2026, 08:38 AM
Reviving this thread, have two separate instances where there's excessive oil consumption in semi-fresh engines. Both cases are where it appears during high(er) RPMs on extended highway cruising.
mklinger - Why not just leave the valve covers vented in your draft setup?
  #45
Old 02-25-2026, 01:49 AM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
On all my sports cars, big 8 or 10an PCV fitting into a catch can then getting drawn on either by the Turbo inlet pipe or on my GTO the intake pulls on it through the can. With my Talon I added a 12v electric Star Machine vacuum pump that pulls 10" at WOT and I might add this on my GN. That'll add 2% power and stops all leaks from CC pressure.
The GTO doesn't get any real vacuum at WOT so it's sort of a dead system that only the dual breathers help at WOT. Even those lame smog pumps pulling 2-3" would help here.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
  #46
Old 02-25-2026, 08:54 AM
True on not pulling vacuum at WOT, but those are usually short blasts anyway. You don't cruise down the highway at WOT for any considerable time.
I'm not against pumps, I just prefer not to because it's clutter in my opinion. If I had a dedicated track car, or one that sees a lot of extended WOT, I would do a pump.
The two cars that are experiencing pull-thru of oil show it on #7 & #8 plugs mostly. It's a little less than a qt every 3k miles, but it's enough to load the plugs up some. And I know the booster is good on both of them.
  #47
Old 02-25-2026, 08:39 PM
PCV positive CV. PCV uses a vacuum pull.
Makes me wonder about NCV; negative CV like No ventilation. Im easily confused.
Vacuum manifold pull, and Breathers on the Valve Cover really make the PVC positive. Factory vent tube into the air cleaner is close enough to he same. HIS
  #48
Old 02-26-2026, 11:39 AM
Kenth's Avatar
Kenth Kenth is offline
At WOT valve cover breathers vents crankcase gases to the atmosphere (open PCV system) while the valve cover tube (closed PCV system) vents the same gases to the air cleaner for combustion.
At idle and cruising speeds the air goes into the crankcase thru the breather or tube.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
  #49
Old 02-26-2026, 07:12 PM
73ta's Avatar
73ta 73ta is offline
Anybody running the two stage adjustable PCV valve. I am trying one currently.
  #50
Old 02-27-2026, 02:12 AM
GOAT8U2's Avatar
Here's something I finally noticed after owning this car for 30 years......I don't have a rear main leak on my GTO anymore, I ditched the PCV and added a fitting so the crankcase is 100% always bypassing pressure. WOT is where you get the most blow by the rings to build crankcase pressure so this valleypan fitting will help, even though there's not much vacuum draw through the intake it's still getting some minor relief and the breathers can barely handle the rest.
The issue is a PCV that closes shut at WOT, you lose this as a crankcase vent and then you're blowing pressure out the dipstick and rear main. Dual breathers alone can't really handle 400ci+ to vent at WOT, we all generally have rear main leaks and we all go WOT a little or a lot.
The PCV is our issue, ditch this IMO and use the hole as a vent into a can with vacuum draw and you will be happy because you'll no longer putting a towel on your garage floor under your engine. Hahaha
  #51
Old 02-27-2026, 05:20 AM
Kenth's Avatar
[QUOTE=GOAT8U2;6605723The issue is a PCV that closes shut at WOT, you lose this as a crankcase vent and then you're blowing pressure out the dipstick and rear main. Dual breathers alone can't really handle 400ci+ to vent at WOT, we all generally have rear main leaks and we all go WOT a little or a lot.[/QUOTE]
Time for a leakdown test?
Sounds like your engine suffers from piston ring blowby.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
  #52
Old 02-27-2026, 09:03 AM
Most of my prior 455s had no blowby idle thru rpm. Those definitely had a PCV hose to the intake, and some had a Valve Cover Breather.
My last 455+060 in the Black 68 GTO stayed remarkably dry yet started-out with a rear Main leak that fixed itself after a few years.
Since early 80's had a couple 428 455 builds with blowby under load. And 1 of them had blowby at idle. The idle blowby is a real bummer that warrants a redo.
Is why if i go into a dry Build ( rods upgrade, etc) i reuse the rings and donta touch the CYLs.
  #53
Old 02-27-2026, 10:26 AM
Tandyman Tandyman is offline
A PVC valve actually restricts flow at high vacuum and is open at WOT.
This is how a PVC valve works
https://comtires.com/blog/auto-repai...-of-a-bad-one/
Glenn
  #54
Old 02-27-2026, 01:13 PM
Schurkey Schurkey is offline
Mistake in logic. The PCV system has two "vents", (the PCV valve itself, and the "fresh air inlet" which doubles as an outlet if there's crankcase pressure.) The "fresh air inlet" is ALWAYS open to the atmosphere, or to the air cleaner housing. Either way, if there's pressure in the crankcase, it gets vented.
I think your engine has excessive blow-by, if the breathers can "barely handle" that amount.
Not true. The PCV is fully-open at WFO, but there's little vacuum to pull the fumes.
Again, if you've got more blow-by than DUAL breathers can accommodate, so that the crankcase has enough pressure to force oil out the rear main, or pop the dipstick up out of the tube, your engine needs help. Fix the excessive blowby, and the PCV system is good-to-go if it's in proper operating condition.
