Can’t find code NO any info on tanks codes? Thanks
Should be a radiator chart in the service manual under the engine cooling chapter. Codes are listed there IIRC.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2015 Chevy Express ![]() 2024 Cadillac LYRIQ |
What application
Not sure if this is what you're looking for...
Thanks unfortunately I don’t see NO
I can’t find it at all anybody ever see one with NO code?
That would be an ON code. I did a quick search and all I found was a Camaro forum question regarding an ON tank code found on a 68 Camaro. No one there knew what it was either.
Possible replacement radiator?
| The Following User Says Thank You to OG68 For This Useful Post: | ||
The ON or NO is the tank code while the codes in the list posted is the assembled radiator codes. I have never seen a chart with the tank codes.
The codes (Camaro perspective) are explained by the CRG at https://www.camaros.org/coolingsystems.shtml#usage I believe my '68 has the original UP code (400 w/AT) Harrison. It also has the ON/NO tank code. Was the ON used for other radiator assemblies? I don't know. Perhaps a good old radiator shop would have a Harrisom parts cross reference book??? I had my original radiator recored in '78, 86, and 11. The UP code tag/plate was missing so I had one added in 2011 during the restoration. |
| The Following 2 Users Say Thank You to JimFB400HO For This Useful Post: | ||
The IL and ON tanks were used on the '68 or "69 UP radiator.
So long, farewell. |
| The Following 2 Users Say Thank You to Held for Ransom For This Useful Post: | ||
