Old 03-31-2026, 12:55 PM
post toastie's Avatar
Last weekend I installed new engine harness on Goldie (I bought through Ames ) and I installed stock point distributor. Harness fits good and the 215 is running and starting well.
  #1842
Old 03-31-2026, 01:56 PM
Shiny Shiny is offline
Originally Posted by 67drake View Post
... First day back home and doing fine. Too much on my plate for permanent naps right now. ....
Glad to hear. Take care of yourself.
  #1843
Old 03-31-2026, 07:37 PM
SRGN SRGN is online now
I was going to just pull the car out to move some stuff around, decided to just go for a half hour drive since I already pulled outside.
The Following 5 Users Say Thank You to SRGN For This Useful Post:
  #1844
Old 04-01-2026, 10:23 PM
Green Elephant Green Elephant is offline
Well, don’t think I’ve mentioned it here, but was diagnosed with prostate cancer back in the fall. After many Dr. appointments on how to proceed, I decided to have it removed altogether, instead of radiation and hormone therapy. First day back home and doing fine. Too much on my plate for permanent naps right now.
My ‘55 still is in the upholstery shop, and when they removed the carpet, the rubber on the gas pedal pretty much fell apart. I found a nice one on Facebook, and it was waiting for me when I got home last night. Looks like it will clean up almost perfect, except for minor scuffing. It always amazes me when fellow Pontiac owners go out of their way to give great prices, or even give stuff away to fellow enthusiasts to dig up parts they need.
I hope your future is bright after your prostate surgery. My Dad is 86, he went the radiation and hormone route and has had quite a bit of trouble with his colon and other issues. I’m thinking he would have decided to go the same route as you if he had to do it all over again. Best wishes.
The Following User Says Thank You to Green Elephant For This Useful Post:
  #1845
Old 04-02-2026, 03:04 PM
67drake's Avatar
67drake 67drake is offline
I actually have 3 good friends who have been through this. 1 had it removed, with no regrets. The 2 that did radiation/hormone, one of them has had complications and his PSA numbers are back up. He told me if he had to do it all over again, he would have just had it removed. That was one of the deciding factors on which way I went.
‘55 Catalina
  #1846
Old 04-02-2026, 04:39 PM
Bought a phone cover to match the Orbit Orange GTO I don't have
  #1847
Old 04-03-2026, 04:04 PM
Verdoro 68's Avatar
Sent the Comp off to it's new owner in Texas.
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 4 Users Say Thank You to Verdoro 68 For This Useful Post:
  #1848
Old 04-07-2026, 04:48 PM
srmmmm's Avatar
srmmmm srmmmm is offline
Checked progress on the bird at The House of Hotrods and things are looking better. New reproduction RAIV intake from OER had much better fitment, but one of the coolant passage sensor holes was tapped to deep and wouldn't seal. With some research we determined that the TCS sensor wasn't needed to make the engine harness work, so a nice aluminum NPT took care of the situation. All the HVAC controls work properly with an outside vacuum source, but vacuum is not getting past the canister to the switch when running off the engine. Either a bad canister or a pinched hose.
The major culprit are the front seat tracks. So we've now learned that the 1970 seat tracks are one-year only and so is the floorpan. The bottom section of 1969 tracks aren't long enough to match the holes in the floor, and the bottom section of the 1971-74 tracks are too low and the adjusters hit the floor. So they're going to take apart my originals and the new 1969 tracks and reassemble the new uppers with their bearing cages with my original lowers. I'm glad I'm not doing that one.
All should be well though to get the car into the Arlington car show on June 6th.
The Following 3 Users Say Thank You to srmmmm For This Useful Post:
  #1849
Old 04-09-2026, 05:23 PM
tempest1964's Avatar
Finished up the rearend. Man oh man.
The Following 2 Users Say Thank You to tempest1964 For This Useful Post:
  #1850
Old 04-10-2026, 12:01 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Moved stuff around to make room to pull the transmission from the '26, to learn why its so noisy.
The Following 4 Users Say Thank You to Jack Gifford For This Useful Post:
  #1851
Old 04-10-2026, 07:47 PM
carcrazy carcrazy is offline
I intended to work on the 67 Goat today........unfortunately my wife had other ideas!
The Following 3 Users Say Thank You to carcrazy For This Useful Post:
  #1852
Old 04-11-2026, 09:15 AM
Yea me to;
Name:	rear recliner.jpg
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
  #1853
Old 04-11-2026, 02:42 PM
form74's Avatar
form74 form74 is offline
Remove the AC box under the hood hasn’t worked for years.
Now I need to decide if I’m getting the AC cover delete that has a provision for a blower motor or just cover up everything with a flat plate that is also offered
My blower fan hasn’t worked in a long time probably some type of electrical issue
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
The Following 3 Users Say Thank You to form74 For This Useful Post:
  #1854
Old 04-11-2026, 05:05 PM
7t4mula's Avatar
7t4mula 7t4mula is offline
So are you planning on updating with something like Vintage air system? That’s what I did. Installed the flush plate and looks very nice!
  #1855
Old 04-11-2026, 08:02 PM
Put gas in the 62 and pulled it out of the garage. Going to sell the current tri power engine in it so took some video of it running along with temp and oil pressure video. Did a little wiring on the 67 GTO and then stripped the paint of the from the glove box door to get it ready for repainting.
The Following 2 Users Say Thank You to carcrazy For This Useful Post:
  #1856
Old 04-12-2026, 12:58 AM
Installed the Retrosound head unit in my 62, maybe tomorrow I'll install the amplifier. Sounded a lot better than I thought it would, previous owner had put a Pioneer CD player in the glovebox and it was pretty weak. Got distracted trying to figure out where I'm moving the alternator so I can get the compressor installed for the upcoming AC install.
The Following User Says Thank You to SRGN For This Useful Post:
  #1857
Old 04-12-2026, 06:17 AM
Drove the 71 down to a car meet in Setúbal. Windy and chilly.
Apple maps ran me thru every back street it could find. I could not cross the main drag as downtown was having a big bike race. Had breakfast and headed back.
One street encountered; no Darksiders here! Mirrors barely cleared.
Why yes, those are tiny garages...
Name:	Setubal narrow street.jpg
The Following 9 Users Say Thank You to Scarebird For This Useful Post:
  #1858
Old 04-12-2026, 10:54 PM
VCho455's Avatar
VCho455 VCho455 is offline
Wandered around the Portland swap meet for the last 3 days picked up some goodies for the Firebird and the GTO. I also spied this rare high performance oil pan.
The Following 3 Users Say Thank You to VCho455 For This Useful Post:
  #1859
Old 04-13-2026, 12:16 AM
It wasn't fun, but the transmission is out of the '26. At least the rear end didn't need to be moved back- the U-joint comes apart, unlike many other torque tube arrangements. Not draining the tranny first was a mistake- it rolled onto its side on the floor, so I've got a huge puddle of gear oil (the top is wide open with the shifter removed).
Can't find a single thing wrong with it! That leaves just the rear end that could create the noise. Removing it should be straightforward (?).
Pulling the tranny wasn't a waste- I wanted to look at the chattering clutch anyway. The disk needs re-lining as it's down to a couple of the rivets. I'm surprised that the lining appears to be semi-metallic- perhaps added sometime during its hundred year life. I'll go to non-metallic, hoping for smoother engagement.
Now... back to cleaning up 3 or 4 pints of gear lube...
The Following 6 Users Say Thank You to Jack Gifford For This Useful Post:
  #1860
Old 04-14-2026, 01:32 AM
Verdoro 68's Avatar
The relatively new Right Stuff master cylinder on Cole's car kicked the bucket out of nowhere so we changed that out and bled the brakes. The replacement master used the long push rod. I have never had a master cylinder use that before. I was so confident that I would never have one that used one that not too long ago I tossed two of the long rods from left over projects in the trash. Nothing Summit couldn't fix. Normally I'm the one who cracks the bleeder valve under the car, but Cole volunteered today. I did not say no.
Not Pontiac related, but when I ordered the long brake pushrod for the Venura, I bought a new set of Stewart Warner gauges for the Javelin. The index on the bottom of the oil pressure is off so it sits crooked in the bezel. That's some kwalitie kontrol for you! Can't decide if it's more annoying to send it back or just fix the slot in the bezel so I can rotate the gauge. Sheesh.
ID:	668160   Click image for larger version
ID:	668161   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
