| Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
Friend of mine has a 09 Malibu, 2.4 L engine, losing pint of coolant in 30 miles! Pulled plugs, cylinders are dry. No leaks on ground. Crankcase oil is "milky". Head gasket or water pump are usual suspects, anything else he should consider (other than buying a used Pontiac) ?
The 2.4 ecotech's are known for water pump failures, but it is not a 5 minute job as the waterpump is run by the timing chain and requires the use of a keeper tool, and if it were my car I would plan on changing the timing chain and guides at the same time as it isn't that much more work. It's a weekend job if you do it yourself, a shop will charge $1200-2500 depending on your location for the job, plus parts.
Do you see any external leakage? A head gasket or cracked head is possible also. How many miles on the car?
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 1971 Fiat 130 Coupe 3.2L SOHC V6, ZF 5-speed 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 05 Dodge Magnum 3.5L SOHC V6 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
Thanks for your reply, I'll pass along the info.........
....and no water on ground, I'll find out how may miles it has rung up
135K
Unfortunately if the car has been driven much with a "milkshake" in the crankcase, the bearings are also probably damaged. Just a bad situation overall. I personally would find it hard to invest the necessary $$$ to repair that engine. Kelly Blue book lists the value of that car at $860.00 in running condition. Not much room to work with on that one.
What engine?
