Old 04-15-2026, 10:07 PM
grd777 grd777 is offline
Default what is this part for
found this in a box not sure were it goes
ID:	668270   Click image for larger version
Old 04-16-2026, 04:49 AM
dataway's Avatar
dataway dataway is offline
Looks like a splash guard for a Fleem Reamer.
Old 04-16-2026, 08:43 AM
burd's Avatar
burd burd is offline
Foreman grill spatula
Southern Hamtramck Institute of Technology , Alumni
Put some 8” flakes and BFG’s on dude!, like everyone does🙄
Burds Literature, nOS factory Brochures, Glovebox literature, & black & blue freedom toppers.
1978 YEE
1995 Q45
#whoremembers
Old 04-16-2026, 09:55 AM
78w72 78w72 is offline
Heat shield of some sort? Aside from maybe a 80/81 turbo car, not sure if thats even a 2nd gen firebird part.
Old 04-16-2026, 03:27 PM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
Bears a resemblance to the starter heat shield, but that's not it... not sure what that is. May not even be a part for your car.
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
Old 04-16-2026, 06:04 PM
sure looks like the heat shield that bolts to the intake manifold on an '80 or 81 Turbo 301 Pontiac.
This heatshield deflects heat from the back of the AIR (smog) pump. without it, heat damage will result to the diverter valve.
As part of performance mods, have removed the smog pump, associated brackets, the crossover supply pipe, along with vacuum hoses,
& the single groove wp pulley on quite a few '80 Turbo cars. The '81 Turbo's (except Export cars) had all the C4 crap on them, and the smog pump & supply line are different.
Old 04-17-2026, 10:41 AM
I mentioned a turbo heat shield too, but thats doesnt look like one from a turbo 301. Heres a pic of a turbo heat shield, its shaped different and slightly different mount hole arrangement.
Thats a heat shield of some sort but not from any 80/81 turbo Ive seen. Might be like nuclear said and not even from/for your car?
I removed the emissions/smog pump stuff on my 81 turbo too, but instead of eliminating the parts totally, I kept everything installed for a stock look or for a future owner to put it all back if desired. I just gutted the smog pump then let it act as a free spinning pulley in order to keep the stock belts.
Name:	301t heat shields.jpg
ID:	668322   Click image for larger version
Name:	heat shield.JPG
Old 04-22-2026, 08:29 AM
Default new photo
from a 80 turbo trans am
Old 04-22-2026, 09:20 AM
Thats the shield I showed in the pics above that is shaped different. Maybe 1980 is very different from 1981?
