Are all 8 bolt water pump pulleys the same diameter? Wondering if the air conditioned cars had a smaller pulley to increase fan speed? Car stays at 180 regardless of ambient temperature as long as it’s rolling however temperature rises quickly when stopped. Currently have 7 blade fan, Hayden heavy duty clutch, stock shroud, upper baffles (not lower), largest Cool Case radiator that will fit, water pump plates clearanced, and initial timing at 12 degrees with full manifold vacuum advanced. This is for my 1968 Firebird 350, stock, 066 cam with factory exhaust manifolds and dual exhaust. I fret when in traffic on hot days…
Ac pulleys for the water pump and crank are a different size than non ac.
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Royal Pontiac (Dealer# 07-679) 70 Formula 400/auto |
Does your pump have the superior factory cast iron impeller and have you checked and if need be set the baffle plate to impeller clearance?
There are also a sealing rubber grommets in steel tubes that goes between the baffle plate and the timing cover on each side and there has to be a good seal made there when the baffle is pushed up against it. If not shims can be had to raise them up off of the timing cover to get the needed compression and seal to be made. Also your fan blades no matter how many should be spaced such that they sit half way in and half way out of the shroud . 210 to 215 degrees is not too hot when sitting at a hot idle with the AC on as long as the temps start to drop once above idle rpm and at 30 mph. Are you boiling coolant out into your catch can at these times? Have you got all the air out of your cooling system by burping it once the T stat opens and coolant flows?
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 04-18-2026 at 12:11 PM. |
Ah. Thanks .
It’s been a long time since I had a 68 apart.
I installed the ac pulleys on my 68 Firebird and it did help to cool it |
I’m a big proponent of those stainless flex fans, they really move a lot of air at idle. Have a 19” on my 66 GTO, albeit with a large 8” water pulley and a small 6.5” crank pulley to slow the fan down in relation to engine rpm. Runs at thermostat temp in any traffic idle conditions in south Alabama summers.
But I would caution over-driving a flex fan using a small water pulley, which would make the fan spin faster than engine rpm. With my setup at 6000 rpm engine speed, my fan is spinning at less than 5000 rpm. If you use the small water pulley you will spin the flex fan approaching 7000 rpm at that same engine speed, so be aware of that aspect. When Pontiac used those flex fans they were under-driven with large water pulleys
You should be able to get your cooling issue straightened out using a factory clutch fan. Our Firebird 400 (automatic) with factory cooling system used to heat up a little with the A/C on in traffic/sitting at lights. We installed a couple small pusher fans on the radiator that switched on with the compressor, and that seemed to work well enough here in AZ for 10 years. But over the winter I completely redid the cooling system so that I could jettison the fans. I installed a remanufactured 8 bolt water pump with the tall vanes, a new Cold Case radiator, a Robertshaw high flow 180 degree thermostat, and a Hayden 2731 clutch (a Cadillac part with longer snout so the factory fan sits .6" or so further in the shroud). I'm not sure which part or combination of parts is responsible, but the car no longer heats up in traffic or while sitting, even with the AC on 100+ degree days.
"If the best Mustang is the Camaro, the best Camaro is actually the Firebird" David Zenlea |
