#1861
I spent the better part of Thursday and Friday down at the Portland swap, but made the mistake of wasting part of one day at the expo center. Scored some good deals at PIR this year though - and got plenty of sun!
#1862
In the process of restoring my 62 tripower air cleaner. Blasted down to bare metal and working from there. Had a few pin holes in the top that I will have to repair.
My money talks to me-it usually says goodbye! |
#1863
Nothing, but I ordered my full comp suspension from PTFB.
#1864
Nice, I've always said the easiest part is ordering the parts 🤠
#1865
Yep. And I'm an expert at that part.
![]() One of these days I'll finish up my fuel system and that'll show ya.
| The Following User Says Thank You to jhein For This Useful Post: | ||
#1866
Darn picture is sideways
74 Formula Below motor destroyed fall of 2023 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.061 @ 110.74 12.092 @ 112.43 12.128 @ 111.71 461 stroker Edelbrock 87 cc dport heads Performer RPM Same Ram Air manifolds, and quadrajet 75 Formula 400 / 4-SPD matching numbers |
#1867
Looks good Gary
#1868
form74, crop the orig. pic to eliminate the info (IMG...), rotate and repost.
#1869
Corrected picture as suggested, this is the UMI brand cover
#1870
Installed Hood. Checked all gaps. Used some foil to check clearance for air cleaners. Victory!
#1871
Beautiful!
| The Following 2 Users Say Thank You to Shiny For This Useful Post: | ||
#1872
Replaced convertible top side cables; one had broke.
| The Following User Says Thank You to Scarebird For This Useful Post: | ||
#1873
Got the 7( out, checked a few things under the hood and took it for a cruise
#1874
Looking good Gary
#1875
Other than changing the oil for the driving season, I decided to mount my rattle can restored original dealership license plate frame. Almost all the chrome was peeled off of the frame, So I looked and found an old rattle can of "Bumper Chrome" and decided to give it a shot. I think it turned out OK, Compared to the price having it recrhomed.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 1971 Fiat 130 Coupe 3.2L SOHC V6, ZF 5-speed 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 05 Dodge Magnum 3.5L SOHC V6 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
#1876
very nice (borat voice)...
Esquire '74 T/A 455 Y-code SD clone previously on Dawson's Creek: '74 T/A 400 '81 AMC SX/4 '69 FB 350 |
#1877
Went to start the 67 GTO and all I heard was the dreaded "click." A quick check showed the battery was fully charged, all cables tight...and the voltage doesn't drop when it clicks.....guess further evaluation is going to be required.
#1878
Give the starter a whack with a hammer while somebody turns the key.
#1879
Took in the SEASON opener, "for me at least".
Great weather and turnout. Was honored with the top in class award. CRUSING SEASON IS NOW OPEN DRIVEM' if you can!
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car.
#1880
I can’t wait to finally get my ride out this season and go to some shows!
********************************* The 1970 Pontiac Firebird Formula 400... Lean, mean, tire-scorching machine! |
| The Following User Says Thank You to 7t4mula For This Useful Post: | ||
