Old 04-24-2026, 09:50 PM
tom s tom s is offline
Cleaned up the 62 GP and 63 Lemans for the Seal Beach car show in the morning.Tom
The Following 4 Users Say Thank You to tom s For This Useful Post:
  #1882
Old 04-24-2026, 11:49 PM
Gary Logan's Avatar
Gary Logan Gary Logan is online now
Formerly GnXRanch
Swapped out the headliner and rear package tray on the '65 2+2. I forgot that the tacking strips on a 61 year old car apparently evaporate at year 50. Still have to put the sail panels in and put the trim back up. Maybe next week.
65 Catalina 2+2, 455, 6x-8, 2802, 4-spd
65 Catalina 4dr Hardtop, 389 4v, Auto
The Following 2 Users Say Thank You to Gary Logan For This Useful Post:
  #1883
Old 04-25-2026, 09:29 PM
form74's Avatar
form74 form74 is online now
Got the gauges installed in the console after running a new line thru the firewall and unplugged the AC wiring under the dash so It could remove the wiring under hood.
Had to remove the console to accomplish this.
ID:	668817   Click image for larger version
ID:	668818   Click image for larger version
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
The Following 3 Users Say Thank You to form74 For This Useful Post:
  #1884
Old 04-26-2026, 08:19 AM
Torquewar's Avatar
Torquewar Torquewar is offline
Some work going on . Hey Gary why is the engine out.?
  #1885
Old 04-26-2026, 08:25 AM
form74's Avatar
It never performed, so it’s being refreshed lots of issues found from the previous builder 😢
74 Formula
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Performer RPM
  #1886
Old 04-26-2026, 08:27 AM
Torquewar's Avatar
Right I couldn’t remember…
  #1887
Old 04-26-2026, 04:08 PM
Jeff Hamlin's Avatar
Yesterdays weather was fantastic, so I blew off yard work and headed over to P-Town for some C&C.
Great morning and ran into a fellow Pontiacer from another site
The Following 7 Users Say Thank You to Jeff Hamlin For This Useful Post:
  #1888
Old 04-26-2026, 07:17 PM
7t4mula's Avatar
7t4mula 7t4mula is offline
Good to see the progress there, Gary! And that’s a creative way of hanging that transmission!
Your ground strap hanging in there reminded me I need to get a new one and install on my 70 also! Thanks!
  #1889
Old 04-27-2026, 11:56 AM
srmmmm's Avatar
srmmmm srmmmm is offline
Originally Posted by Jeff Hamlin View Post
Took in the SEASON opener, "for me at least".
Great weather and turnout.
Was honored with the top in class award.
CRUSING SEASON IS NOW OPEN
DRIVEM' if you can!
Congrats on a great looking win! Mine will be in its very first show June 6th. I'm just hoping for a day without hail in Texas then!
The Following 4 Users Say Thank You to srmmmm For This Useful Post:
  #1890
Old 04-27-2026, 12:12 PM
Took the '72 Trans Am on a 20 car poker run yesterday in the rain. Was about a 170 mile round trip run up into the foothills.
The Following 6 Users Say Thank You to 71GP76TA For This Useful Post:
  #1891
Old 04-27-2026, 05:24 PM
JimFB400HO JimFB400HO is offline
For the first time in several years, starting to care about the '68 Firebird again. Today, with limited physical abilities (healing knee replacements), I started searching for the source of smoke rising from the back of the right side inner fender area. It occurs once warmed up and lasts until whatever it is finishes burning off. So far, I still don't know the source even after a couple hours of looking around the area with an endoscope. With a 400HO w/longbranch manifolds, TH400, and AC blocking access, I have not found the leak, that I assume has to burn off the exhaust system. I know it's minor because there's not a drop of anything on the garage floor in the area of the smoke after sitting for years.
The Following 6 Users Say Thank You to JimFB400HO For This Useful Post:
  #1892
Old 04-27-2026, 05:44 PM
Skidmark's Avatar
Skidmark Skidmark is offline
[QUOTE=JimFB400HO;6613790]For the first time in several years, starting to care about the '68 Firebird again.
True love never dies.
Glad you're back at it.
72 Lemans sport 462 auto
75 Trans Am 4 speed 39k miles
  #1893
Old 04-27-2026, 06:32 PM
[QUOTE=Skidmark;6613794]
Thanks! Yep, there's something special about it. In my case, it's owning it for 57 years and part of a lot of life.
  #1894
Old 04-27-2026, 09:38 PM
7t4mula's Avatar
Jim,
I’ll bet you’ve got some leakage in the oil filter mounting bracket, or perhaps the pressure sending unit. Good luck to you on finding the source!
Ironically, I was just digging around there myself on mine today… that’s why I thought of it. After installing the Doug’s Headers, I cannot get the standard sized oil filter in there, so trying to decide which route to go to be able to get this car fired up again!
  #1895
Old 04-27-2026, 09:48 PM
Originally Posted by 7t4mula View Post
Jim,
Try this:
https://forums.maxperformanceinc.com...d.php?t=468168
Or perhaps the smaller diameter 1979 Cadillac filter mentioned in that thread.
  #1896
Old 04-27-2026, 11:51 PM
Jim,
Thanks! I'll check that. I have the factory original oil filter mounting and the RA/HO Longbranch adapter with the multiple gaskets to angle the filter. (Never touched since the factory assembled it.)
The Following User Says Thank You to JimFB400HO For This Useful Post:
  #1897
Old 04-28-2026, 08:56 AM
Put in a functional windscreen washer setup on the 71. Of the dozen GM cars I had that used this wiper pump setup, I think maybe one actually worked correctly.
I used a below tank pump (self priming) from a 1975-79 Firebird supplied by this forum's sponsor. It works quite well.
This can also be used on a stock reservoir if a 9/16" hole is drilled in the bottom. A 9/16-12 nut with sealant mounts the pump. Power can be run to the pump, and the washer switch grounding feed is used to trigger operation. You may need to adapt hose size.
The Following 2 Users Say Thank You to Scarebird For This Useful Post:
  #1898
Old 05-01-2026, 06:36 PM
form74's Avatar
Picked up my motor, now need to get the exhaust manifolds etc on and than off to the dyno.
74 Formula
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Performer RPM
The Following 6 Users Say Thank You to form74 For This Useful Post:
  #1899
Old 05-02-2026, 01:37 AM
Redpiston Redpiston is offline
Default J
Moved my 2+2,parts, and tools from Richland WA to Evanston WY.
The Following 5 Users Say Thank You to Redpiston For This Useful Post:
  #1900
Old 05-02-2026, 10:07 AM
7t4mula's Avatar
Fantastic Gary! If she runs half as good as it looks you’re in business!
The Following User Says Thank You to 7t4mula For This Useful Post:
