Old 05-14-2026, 05:49 AM
3X24SPD 3X24SPD is offline
Replaced the velocity stacks on the carbs with a fancy new piece
1966 GTO (Red) WARPATH
469CI TriPower 4-Speed
1965 GTO (Black) TRIPOWR
455CI TriPower 4-Speed
1965 GTO (Blue) 3X24SPD
464CI TriPower 4-Speed
1963 Tempest (Red) VIOLENT
440CI 2X4 Mag Nash / T400 (for now..)
The Following 5 Users Say Thank You to 3X24SPD For This Useful Post:
  #1922
Old 05-14-2026, 07:58 AM
Marked my balancer for 36 degrees before top dead center. Now if my wife will assist with taking the engine up to RPM at 200 RPM increments while I observe with timing light I’ll begin my mechanical advance tune…. Realistically I’ve just got a marked balancer. She says it makes her “hair stink”.
The Following 6 Users Say Thank You to PontiacHO For This Useful Post:
  #1923
Old 05-14-2026, 10:16 AM
Shiny Shiny is online now
Made my wife laugh... she understood immediately.
  #1924
Old 05-15-2026, 12:44 PM
67drake's Avatar
67drake 67drake is offline
Just got a text from the upholstery shop. Turns out the cloth interior in my ‘55 Catalina was actually very well made, but very old and beat, seat covers. She found original material under the cloth seats. I figured these were long gone. Not that I would have wanted them to look this way.
The seat covers are in the background. Kinda a white/green tweed They were so tight and fit so well, I thought it was an old upholstery job.
‘55 Catalina
The Following 2 Users Say Thank You to 67drake For This Useful Post:
  #1925
Old 05-15-2026, 05:13 PM
form74's Avatar
form74 form74 is offline
Got the oil pressure fittings set up to run oil pressure next to the distributor
Then swapped the brake booster out, what a pain in the a$$
Still need to bleed the brakes
ID:	670125   Click image for larger version
ID:	670126   Click image for larger version
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
The Following 3 Users Say Thank You to form74 For This Useful Post:
  #1926
Old 05-15-2026, 07:03 PM
Default TriPower minor revamp
These were a set of TriPower Carbs that I bought 35+ years ago.
They came off a 1964 421 HO- which originally had vacuum actuated outboard carbs
Sold the useless (to me) bare ’64 intake manifold to IA Dick Duclow- and ended up with the carbs for free.
The carbs had an aftermarket mechanical conversion linkage that someone had installed, and some ugly ass homemade fuel lines.
The Following User Says Thank You to 3X24SPD For This Useful Post:
  #1927
Old 05-15-2026, 07:04 PM
Default Revamp
I initially wanted to replace the ugly fuel lines- but the aftermarket mechanical linkage prohibited installing factory fuel lines that due to interference.
I liked the nostalgia of the aftermarket linkage- which utilized a replacement longer center carb throttle shaft- so I just lived with the ugly fuel lines.
I’m sure I probably could’ve fabricated something much nicer years ago with very little effort- but that just wasn’t high on my priority list.
Finally decided to change it up a bit- and bought a replacement ’65 center carb throttle body, some factory ’65 fuel lines & factory mechanical linkage.
ID:	670136   Click image for larger version
  #1928
Old 05-15-2026, 07:06 PM
Default Revamp
Rear Carb Linkage Arm
ID:	670138   Click image for larger version
ID:	670139   Click image for larger version
  #1929
Old 05-15-2026, 07:07 PM
Default Revamp
Revamped
The Following 6 Users Say Thank You to 3X24SPD For This Useful Post:
  #1930
Old 05-18-2026, 12:00 AM
post toastie's Avatar
I put a few miles on my judge today , bought some more 91 octane for it, retightened fuel line . It is still running good.
The Following 4 Users Say Thank You to post toastie For This Useful Post:
  #1931
Old 05-18-2026, 09:57 AM
srmmmm's Avatar
srmmmm srmmmm is offline
Picked up the Bird from House of Hotrods last week. After five months, mostly due to parts availability, I am pleased to report they nailed everything. The HVAC system works with the proper outlet selection for defrost, bi-level, A/C and heat. No more vacuum leaks or coolant leaks with the intake manifold. The Q-Jet is finally behaving now the way it should without those vacuum leaks. The front seat tracks work perfect. The front clipped was realigned and there's no more tire rub from the left front fender and the hood fit is perfect.
The wife and I have taken it out on a couple of dinner dates and it has been very "driveable". I just need to chase a tempermental temperature gauge. I suspect the multiple manifold installs may have damaged the sending unit as the needle will come up to about 130, then jump to 160 after 20 minutes. Infrared gun shows the crossover at 205. Regardless, it is so nice to have it running the way it should. Now we'll see how it does in their car show May 30th in Mansfield, TX and the Arlington city show on June 6th. I'll try to do a driving video this next weekend.
The Following 9 Users Say Thank You to srmmmm For This Useful Post:
  #1932
Old 05-18-2026, 11:44 AM
Verdoro 68's Avatar
We had the cars out at the yearly High School auto shop car show. Smaller crowd this year, but always a fun and chill event with some of the alumni dropping by and the school culinary program serving up burgers. Always happy to support the school - we've gotten a lot of use out of that shop!
ID:	670301   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 9 Users Say Thank You to Verdoro 68 For This Useful Post:
  #1933
Old 05-18-2026, 08:25 PM
form74's Avatar
Got the motor in the Formula today
Always a fight with the engine mounts
Thanks to a couple buddy’s who stopped by
Hope to have it running by the weekend
ID:	670343   Click image for larger version
74 Formula
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Performer RPM
The Following 7 Users Say Thank You to form74 For This Useful Post:
  #1934
Old 05-19-2026, 12:47 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Got my two strong-arm sons to set the bellhousing/tranny assembly back into the '26 tonight. The transmission is fine, so it wasn't contributing to the driveline noise- which may be totally due to the loose hub-to-wood-spokes bolts of the left rear wheel (still waiting for custom threads to be machined in the wheel puller I built). Taking the tranny out wasn't wasted effort, as the clutch disk was worn down to the rivets, so I had it refaced. The clutch itself was fine- until I broke it! The flywheel has three dowel pins that engage with slots in the pressure plate- except if you misalign it and start tightening the bolts, as I did. No clutch to be found, so I had the cast pressure plate welded, which warped the heck out of it- needing considerable machining to correct. But the clutch cover (also an iron casting) could not be corrected if warped that badly. So I had the broken pieces just tacked in place while clamped to a flat plate. Then made 1/4" steel strap pieces to go under mount bolts and cover the broken areas. All I can do now is cross my fingers that it might survive....
The Following 6 Users Say Thank You to Jack Gifford For This Useful Post:
  #1935
Old 05-19-2026, 09:02 PM
4dblnkldude's Avatar
I removed my tri power carbs from my 64 to rebuild.
The Following 2 Users Say Thank You to 4dblnkldude For This Useful Post:
  #1936
Old 05-25-2026, 12:27 AM
Test drove the '26 today- the clutch is surviving okay and the chatter is gone. But the drivetrain is just as noisy as before. I guess the differential needs to come out- anybody versed in spiral bevel gears?
The Following User Says Thank You to Jack Gifford For This Useful Post:
  #1937
Old 05-26-2026, 07:54 AM
My father and I installed the folding top almost 30 years ago - other than being a bit faded it has held up well. I picked up this plastic cleaner/treatment after noting it does not contain silicone for the princely sum of 8€.
It worked quite well, but will require another application I think. It does not leave a greasy film like Armor-All and a few others I could name.
I ran across this on a drive to town. No, it is not a giant swimming pool but a portable bullring.
Not something you run across everyday in the USA.
ID:	670962   Click image for larger version
The Following 3 Users Say Thank You to Scarebird For This Useful Post:
  #1938
Old 05-26-2026, 10:30 AM
tempest1964's Avatar
Added a little something to the rear of my ‘64 Tempest Custom with its factory ‘64 one year only bench seat 4 speed Hurst shifter. I’m pretty sure it wasn’t an option in 1964, but hey, I’ve always liked these Hurst Equipped emblems.
1964 Tempest Custom
421 SD clone
KRE 74cc heads
KRE 230°/236° hydraulic roller cam
Rebuilt 3.23 rear end
The Following 2 Users Say Thank You to tempest1964 For This Useful Post:
  #1939
Old 05-26-2026, 08:03 PM
67drake's Avatar
Took the grandkids for ice cream a few towns away. Did a 180 as I passed this Ventura for sale. Wasn’t there a few days ago. A little on the high side for what it is, but looked like a fairly solid car, owned by someone who has no clue how to put graphics on a car.
ID:	670989   Click image for larger version
ID:	670990   Click image for larger version
‘55 Catalina
  #1940
Old 05-27-2026, 07:36 AM
form74's Avatar
Got the motor running in the car yesterday
https://www.facebook.com/share/v/18yvW3wBGB/?
Just need to bleed the brakes so I can test drive it
74 Formula
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Performer RPM
