Old 05-17-2026, 11:02 AM
gtorich gtorich is offline
Default motor mount bolt
Did a search on bolt torque for these, thread from 2012 came up...........im trying to figure out why so many different specs for this, on my 66 manual its 30 lbs, but im seeing anywhere from 65-75 on different sites,
Seems if you look up 3/8 torque even on a grade 8 its around 45, i put mine at 60 lbs, now im second guessing myself.
Got the motor and trans in yesterday, wow nothing going right with those dougs headers, but got it done.
Rich
Old 05-17-2026, 11:10 AM
zippy's Avatar
zippy zippy is offline
Headers are a PAIN. But tight, nothing wrong with 60. I'm prob there or more with mine. Only things I ever TQ, Rods, Mains, heads and Lug Nuts. Anything else is by feel.
Dan Pesonen
"If it ain't broke, modify somethin till it is"
Old 05-17-2026, 11:34 AM
72projectbird's Avatar
I've never torqued motor mount bolts. I just crank em in until they're tight.
60 lbs should be fine.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 05-17-2026, 12:16 PM
Bolts I have never used a torque wrench on.
Carb .
Intake
Trans
Water pump
Timing cover
Motor mount.
Oil pans
Valve cover
Push rod valley pan cover
Exh manifolds
How about you folks?
Let me see what did leave out!
Old 05-17-2026, 02:16 PM
You left the " I " out in your sentence.............love this forum, ask a simple question about why so many different numbers on that spec, and you get this.
Old 05-17-2026, 03:46 PM
What exact bolt are you refering to? mount to block? the long bolt going theu the mount?
For future reference.
I was wondering the same thing as being asked above.
ID:	670233   Click image for larger version
Old 05-17-2026, 06:01 PM
60 seems high for the 3/8 bolt from the mount to block. Might be right for the bolt for mount to frame.
Old 05-17-2026, 06:04 PM
steve25, what is the source of those torque specs?
Old 05-17-2026, 07:49 PM
4dblnkldude's Avatar
Butler website had a nice chart!
Old 05-17-2026, 08:18 PM
The old HO racing part number & spec book.
Old 05-17-2026, 08:42 PM
OK, I thought that looked familiar!
Ok, this is from the 66 manual i have, shows 30 lbs, its the mount that attaches to the block, im not trying to be difficult but im wondering why so many different numbers for the same thing, as per wallace site and a few others, and usually i dont use the torque wrench because half the time you cant get in on half the nuts on the motor..........but since i was putting in the motor and was able to reach them, i said why not. I know alot of my questions over the years have been , lets say short of being smart, im just trying to learn as i go.,
Rich
Name:	Engine mount.jpg
Old 05-17-2026, 08:47 PM
Held for Ransom's Avatar
In the 1967 Pontiac Service Manual, the engine insulators are torqued to the engine at 70 lb. ft. and the single bolt at 50 lb. ft. The rear (transmission) insulator bolts are torqued to 30 lb. ft.
So long, farewell.
Old 05-17-2026, 09:09 PM
Sirrotica's Avatar
The bolts that attach the mount to the block just above the oil pan rail are 7/16" anyway, not 3/8".
The spec i have always used is GUTTENTIGHT, an old German spec that works well in almost any application on non critical bolts, the GUTTENTIGHT spec has always worked for over 50 years of wrenching.
If you think back to the early years of wrenching on automobiles a torque wrench was a very specific/expensive piece of equipment, and not everyone had one in their tool set. My father worked on cars and trucks most of his adult life, so he had one for building engines, most guys that worked on their own stuff used the GUTTENTIGHT spec.................
Internal engine parts, and the lug nuts, after manufactures started using thin throwaway rotors are about the only parts I use a torque wrench for currently, YMMV.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 05-17-2026, 09:21 PM
The single bolt at 50 lb. ft. I believe is for the big car. The Tempest single bolt to mount bracket is 30 lb. ft.
Old 05-17-2026, 09:30 PM
he bolts that attach the mount to the block just above the oil pan rail are 7/16" anyway, not 3/8".....................sorry about that Sirrotica, trying to get this motor and transmission in , im getting numbers confused............got the motor and trans in yesterday, long day for me doing this, im not as fast as some of you guys that been doing this half your lives.
Rich
Old 05-17-2026, 11:05 PM
You are probably correct on that. When I read the 30 lb. ft., it stated bolts as in the the frame bracket bolts and I didn't think that included the long bolt. But full size and Firebird is 50 lb. ft.
So long, farewell.
Old 05-18-2026, 11:34 AM
Sirrotica's Avatar
50# on those 7/16 bolts sounds right if you want a torque spec, but they were never torqued at the factory, they were installed by a torque limiting impact wrench.
Another thing is when the factory sets a flat rate time for warranty work on any operation on a vehicle, they usually do not allow for use of a torque wrench. Every flat rate operation study is done usually with the technician using impact tools, without going over the torquing operation except on critical torque bolts. Yes there is a torque spec given on almost all bolts that hold a vehicle together, but in reality they expect them to be impacted more times than not on the GUTTENTIGHT method.
Just a little insight into the reality of how the manufacturers know most times how fasteners are going to be tightened by technicians in the field. As long as the part stays attached, and the fastener isn't compromised, is sufficient torque.
In all actuality given the accuracy of most torque wrenches, the GUTTENTIGHT method is plenty sufficient for 95% of all fasteners used in an automobile.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 05-18-2026, 01:01 PM
50# on those 7/16 bolts sounds right if you want a torque spec, but they were never torqued at the factory, they were installed by a torque limiting impact wrench...
Sounds to me like they were indeed torqued from the factory.
