Old 05-18-2026, 07:02 PM
gtobird's Avatar
gtobird gtobird is offline
Default Removing engine in 68 that has RAM Air Exhaust Manifolds
I have a 68 Tempest (GTO clone wagon) that currently has the stock D port Ram Air exhaust manifolds mounted to the engine and I'm getting ready to remove the engine. I've got the exhaust pipes disconnected from the manifolds, but the manifold to engine bolts are rusted tight. Is there enough clearance to just yank the engine with the manifolds attached? It would be much easier to remove the bolts afterwards when I have more room to work with my bag of bolt removal tricks.
It looks like the engine will clear to me. The car does have the original A/C setup, but I don't think the suitcase presents any issues.
What say those of you that have done it?
Regards,
Old Joe
68 Firebird Convertible
68 GTO Clone (Tempest) Wagon
Old 05-18-2026, 08:20 PM
form74's Avatar
form74 form74 is online now
I remove and put In my engine with my ram air manifold’s in my Formula , with no issues
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
Old 05-18-2026, 08:41 PM
gtobird's Avatar
Sure, but that's a different engine bay. I would think if it worked in a Firebird, it would work for an A-body, but I'd like to know from somebody who can actually verify it for the same engine bay.
Old 05-18-2026, 09:40 PM
433lemans's Avatar
433lemans 433lemans is offline
I installed my 350 in my 69 Lemans with RA manifolds mounted so it shouldn't be a problem removing the same. A/C equipped car.
Old 05-19-2026, 08:15 AM
gtobird's Avatar
Thanks 433lemans and Form74 for validating. On the Lemans 350 install, the RA manifolds were this style as shown on the Butler Performance website, correct?
https://butlerperformance.com/i-3164...mWCcflxldBNWIw
Old 05-19-2026, 09:37 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
I have pulled mine and reinstalled with the manifolds on
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 05-19-2026, 11:00 AM
AG's Avatar
AG AG is offline
It's easier if you take out the manifold studs to exhaust pipes.
Old 05-19-2026, 12:04 PM
1969GTO's Avatar
1969GTO 1969GTO is offline
Default RAM AIR MANIFOLDS in a GTO
Regards,
Old Joe
Easy to do...
Name:	engine install.jpg
color me gone
The Following 2 Users Say Thank You to 1969GTO For This Useful Post:
Old 05-19-2026, 02:04 PM
Verdoro 68's Avatar
It can be done. I pulled mine with D-port RA manifolds attached and installed it with round ports manifolds with little issue. Watch the frame clearance though.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 05-19-2026, 09:06 PM
433lemans's Avatar
Yes. Same ones. Mine are factory manifolds.
Old 05-19-2026, 10:14 PM
propuckstopper propuckstopper is offline
Regards,
Old Joe
1968 GTO 400 H.O. with the RA exhaust manifolds and a/c. I have had the engine in and out a couple times over 40 years and always do it with the exhaust manifolds attached.
Old 06-01-2026, 09:15 AM
gtobird's Avatar
Thanks to all of you
