Old 05-22-2026, 07:18 AM
BN's Avatar
BN BN is offline
Default 1972 Rally gauges w/120 speedo
72 Lemans sport conv 350-2
OK,
I want to change from warning light cluster to rally gauges on a 120-seatbelt warning car. I have the 120-gauge cluster and want to keep the seatbelt warning system operational. I've searched the forums and found a few different posts about which wires to switch but are conflicting. It seems a lot of the posts refer to guys switching from 120 warning clusters to 140 rally clusters. Has anybody done the switch and can tell me which wires to switch?
Old 05-22-2026, 05:12 PM
Bill, do you have a 1972 Pontiac Service manual?
This should be similar 2 wire swap deal as used to convert '68, 69-early '72 A-bodies from idiot light harness to Rally gauge harness.
I'll ck out my '72 Pontiac Service manual this weekend & post back.
Old 05-22-2026, 06:13 PM
Unfortunately I do not see the wire for the seat belt lamp. And looking at the Ames catalog shows 2 different circuit boards - the harness contact pads seem to be different too.
Name:	72 inst plug.jpg
Old 05-22-2026, 07:20 PM
BN's Avatar
BN BN is offline
No, unfortunately I let it go with the sale of my last 72. I have a wiring diagram but like what Scarebird's post shows it only covers the 69-early 72 wiring.
Old 05-22-2026, 10:02 PM
This may help. Ames has pix of both their printed circuits. I put them both in one pic, then traced the circuits. I would check - it is 3am here and may not be accurate.
Name:	1972 CIRCUIT.jpg
Old 05-23-2026, 10:02 PM
DavesGTO's Avatar
DavesGTO DavesGTO is offline
The legend of connector pads is wrong in the '72 service manual for rally gauges, think the gen light and fuel tank are the two wrong (reversed), been awhile. Use the schematic when switching pins on the connector, schematic is right.
Old 05-26-2026, 09:03 AM
BN's Avatar
BN BN is offline
Don't really know what I'm looking at. Can anybody decipher?
Found one post from 2003 that says:
Shift #1 to #12
Swap #6 and #5
Shift #3 to #2
Shift #2 to #1
Check extra tan 12, can put in slot nc..
Does this sound right?
Old 05-26-2026, 10:22 AM
Held for Ransom's Avatar
Here is the printed circuit board cluster with seat belt diagrams. I haven't verified pinout though.
ID:	670968   Click image for larger version
So long, farewell.
Old 05-26-2026, 10:40 AM
Is this the thread you've referred to?
https://forums.maxperformanceinc.com...d.php?t=426632
So long, farewell.
Old 05-26-2026, 11:28 AM
BN's Avatar
BN BN is offline
That's it...
Old 05-26-2026, 11:40 AM
Well, post #11 should tell you what to properly swap.
#3 gets the wire from #12. #5 and #6 get swapped. That looks like it.
So long, farewell.
Old 05-26-2026, 01:35 PM
johnta1 johnta1 is online now
I tried to post bigger pics of HFR's pics, but this site doesn't support bigger pics.
These are from the service bulletin for the seat belt buzzer harness change.
See if they are clearer?
Rally Gauge pic
No Rally Gauge pic
Old 05-26-2026, 03:07 PM
BN's Avatar
BN BN is offline
I'm gonna try it. I'll let everyone know if it works. Thanks everyone.
Old 06-01-2026, 12:02 PM
Ogre's Avatar
Ogre Ogre is offline
Question
Lots of great info here, so thanks to all of those contributing.
I am at a stage of rebuilding from no gauges to gauges. I have the entire under dash harness out for repairs and am getting ready to do the entire dash before re-installing it. I also have the manuals plus a pdf copy on my computer.
Since the numbers in the '72 repair manual are designating the circuits, and the numbers on my connector (pics below) are not referenced, I want to make sure I match them up. If I take the wide connector location and just write down 1 - 12 next to the manual's 8 - 39 pic will it work?
Sorry for the confusion,
Ogre
ID:	671205   Click image for larger version
“Man will ultimately be governed by God or by tyrants.”
-- Benjamin Franklin
- (1706-1790) US Founding Father
Old 06-01-2026, 05:42 PM
Does this make it easier?
So long, farewell.
Old 06-01-2026, 06:00 PM
Just noticed both drawings show the same layout.
And looking at the gauges printed circuit board, your plug is showing correctly positioned wires.
So long, farewell.
Old 06-01-2026, 06:15 PM
OG68 OG68 is online now
Service manuals were usually printed in August prior to fall production. Since the 120 MPH / Seat Belt Warning instruments were used after Dec 31, 1971, the new modified harness would not be in the service manual.
A Service Bulletin was issued detailing the changes as shown in post #12
Old 06-01-2026, 06:18 PM
Ogre's Avatar
Talking
Thanks, HFR. That makes it clear.
Ogre
Old 06-02-2026, 07:31 PM
Here you go
The Following User Says Thank You to Pepper Judge For This Useful Post:
Old 07-03-2026, 01:58 PM
BN's Avatar
BN BN is offline
Well, tried all the different wire swaps and couldn’t get gauges to work. Bought a new harness from M&H for gauges. I’ll post results. Is the circled green wire the one that needs to be taken out so gauges don’t peg upon start up?
