Old 05-21-2026, 10:28 AM
15bhardwick 15bhardwick is offline
Default Valve Spring Recommendation
Have a NOS Crane Solid Roller Cam and needing to buy springs for it. Cam card in attachment.
I will be using a 1.65 rocker so .687-.22 lash=.665 lift.
260/270 duration @ .050
108 LSA
I can get a 1.85 installed height with my heads.
Was thinking the recommended closed and open pressures look a little light for a solid roller? Is this because of how old the cam is and valve spring tech. has improves so much? Everything I find is at about 200 on the seat and 550 open. Drag race only. 5/16 hollow stem intakes, will buy titanium retainers, shaft rocker system.
Old 05-21-2026, 12:26 PM
Skip Fix Skip Fix is online now
Most folks want at least 200 -240 seat.
Old 05-21-2026, 01:22 PM
Neil Scott Neil Scott is offline
I have 250 on the seat and 690-700 open. But its a pretty aggressive solid roller. [email protected] and .450 lobe lift
Old 05-22-2026, 09:58 AM
chuckies76ta's Avatar
Howards 98644 might work for you. We run a PSI ct1526ml spring with around 220 seat/ 520 open. spinning to 7000 rpm with no issues. There are installed at 2." though.
950 Quickfuel.
Old 05-22-2026, 02:38 PM
A Manley 22440 is a drop in .
It gives 250 on the seat which after breaking in would be 240.
It coil binds at 1.050”
